ACT, you suck
Old Jul 10, 2009 | 09:34 PM
recompile's Avatar
ACT, you suck
Witness the pain -----> http://www.vimeo.com/5547580
As you can see, I have an ACT XTSS clutch that locks me out at high RPM.
I've:
- Had the clutch installed by a professional
- Had the tranny upgraded to a Shep, so the tranny has been off and the clutch fitment checked and adjusted twice
- Adjusted the pedal in various positions, including as far up a it will go
- Tried with/without restrictor pill
- Tried with stock clutch line and stainless clutch line
- Tried with stock front motor mount and Blox front motor mount
- Tried with stock underhood shift bushings and solid underhood shift bushings
There is no getting around it... I get lockout in 2nd and/or 4th every time I go to the track. I can short shift @ 7000RPM to get around it, but anything higher and I'm locked out.
This was a brand new clutch kit with brand new TOB, and it's given me issues since day 1.
Originally Posted by skatermsmn
Just got back from the track and could even break into the 11's because of the lockout issue.
Originally Posted by gsrboi80
ACT Clutch Lockout Member #1 here. Gonna use it for target practice once it comes out. Adjusted every which way from Sunday no help. Mine seems to be about 7800 and up anything below that it'll shift
Originally Posted by BossEvoVIII
Im gunna have to agree. I hate my ACT with a passion, Never again will I even consider them for my evo.
Originally Posted by evokid511
dude i no exactly what u mean!!!! have everything youve done but you got it a little better you get locked out in 4th only i get locked out of EVERY gear if i go above 5.5k!!! i hate my act!!!
Originally Posted by RevMoto
Whomever says act works great doesn't know how to shift fast enough. I have had the same clutch on both of my Evo's and to no surprise I get lock out in every gear. ACT is crap, end of story.
Originally Posted by Macaroni
I have everything. ACT 6 puck sprung, Blox front motor mount, SS clutch line, and shifter bushings and I get locked out in 2nd, 4th, and 5th. If I don't get locked out, I usually grind the hell out of 4th and 5th grinds regardless. I had to stop using NLTS because it was worse than regular fast shifting.
Originally Posted by TTP Engineering
we do not recommend the XT pressure plate in the Evo. It is our opinion that the pull pressure on the plate is too much for high rpm shifting and is more prone to not fully disengaging.
You are one of the lucky ones with the xt and no lockouts Tom.
We would shy away from the extreme pressure plate... it could contribute to lockouts.
The heavier pressure plate contributes to lockouts, especially when paired with a street disc
Originally Posted by zedevo
i have the same issue on my ACT ...
Originally Posted by Jeff_Jeske
Warped this, air gap that, install my ****..... its the clutch. This isn't a problem with the stock clutch. This isn't a problem with exedy stage 1-2 or TD. People running the centerforce, clutchmasters, fidanza, and south bend aren't locking out.
I've run out of fingers and toes counting how many people went from a functional stock clutch to the HDSS and had immediate problems. Then they suck it up and get a twin disk and the problem is gone.
Originally Posted by Colt4g63
ACT is known for this plain and simple no matter what excuses fly....
Originally Posted by WannaRace
<-- Lockout ONLY at the drag strip at high RPM. I am going to guess and say that it is the organic disc (HDSS) heating up from the launch and causing this problem.
Originally Posted by sti.this
running a HDSS here and had lockout issues
Originally Posted by Noize
I had high rpm lockout in my VIII with an HDSS and a 3071R anything past 7000 at the racetrack as well.
Originally Posted by forcepower22
high rpm lockout in EVERY gear here.... saving up for a twin..... clutch needs to go shoot itself in the face.... worst clutch EVER
Originally Posted by Clutchdc5
my friend has a ACT 6 puck right now and has to granny shift 4th or else it wont go in
My VIII locked out at about 400whp Dyno Dynamics. I could shift at 7500 at ~350whp when it was trapping 118, but to trap 120+, it would lock out right at redline. I detuned it for drag racing because of this.
I couldn't hold 1-3 without missing the next upshift. Stock flywheel.
Went back to a stock clutch and could upshift on the limiter no problem.
Originally Posted by evo9ben
act clutch is a big regret it wont let me get into some of my gears spicificly 3rd and 4th unless i granny shift
Originally Posted by davidbuschur
Let me get in with being in agreement 100% on this topic. At one point in time we probably sold more ACT clutches than anyone else. The company has changed, the product sucks and we stopped selling them about 2 years ago.
Originally Posted by magyar86
Add me to the list. At upper 500s, I experienced lock out. Backed down to low 500 and its better.
Street disc with xtreme PP and streetlite Flywheel.
Wish ACT would do something to help their customers.
Originally Posted by partyboy1122
ACT sucks. I pretty much have a 3 speed when I'm at the track.
Originally Posted by WHTEVO
It seems anything over 8k rpm i get locked out. I currently have the sprung six puck.
Aaron
Originally Posted by SRT-TO-EVO
BossEvo on here can join the club as well. He's experiencing lockout issues and synchro issues (can't get in second gear). The clutch is total garbage, and this is nothing new.
Old Jul 10, 2009 | 09:50 PM
evokid511's Avatar
Old Jul 10, 2009 | 09:51 PM
Kracka's Avatar
Jeez. I wonder why some people have no issues while others do?
Old Jul 10, 2009 | 09:55 PM
Solo II Evo's Avatar
Not that i'm some kind of professional, however, after doing two of my own clutch installs, I've noticed that for people who are not familiar with Evo clutches it can be easy to damage the wedge collar/TOB which may (or may not at all) be related to the ability for the clutch to dis/reengage. Might be worth checking out the TOB through the inspection hole on the bottom fo the transmission.
Again, i'm a beginner mechanic, but this is where i'd look.
Old Jul 10, 2009 | 09:56 PM
evokid511's Avatar
i have no idea! its the weirdest thing my firends got my same setup and his is perfect!!!
Old Jul 10, 2009 | 10:04 PM
bbyevo8u's Avatar
did it always lock you out or did it just start happening?
Old Jul 10, 2009 | 10:43 PM
Piro Fyre's Avatar
I get the same lockout with my Exedy OEM clutch. When I can finally get into 4th gear though, it grinds into 4th at high RPMs. 2nd, 3rd, and 5th don't grind nor lockout. It's just 4th.
Personally, I don't think it's the clutch's fault. As someone here said, it might be the TOB. I've heard that the OEM TOBs were better then other manufactures (like Exedy, ACT...) that makes it. If I'm wrong on this, someone feel free to correct me.
My current setup is:
Exedy OE replacement kit that came with a pressure plate and TOB
SS clutch line, fully bled
pedal adjusted right at catch point
re-greased the TOB and fork
Old Jul 10, 2009 | 10:47 PM
Teal2nnr's Avatar
It's not the clutch's fault someone didn't install it right. Mine works fine.
Old Jul 10, 2009 | 10:57 PM
project_skyline's Avatar
How many miles do you have? My friend has the HD version with 40k and it locks out in 2nd and 4th.
Old Jul 10, 2009 | 11:27 PM
ant_turbo's Avatar
What ACT do u have??? I had the issue with my 6puck sprung...
I've:
- Adjusted the pedal as far up a it will go
- Removed the restrictor pill
- Installed a stainless clutch line
For what its worth I have a Fidanza flywheel.
Old Jul 10, 2009 | 11:30 PM
ftlvwrx's Avatar
LOL! ACT FTL
Should have spent the extra $600 for the Exedy Twin disc, I've had mine since the end of may and freakin love it. When straight from install to dyno with no break in and held amazing on the dyno never had any gear lock out and the pedal feel is almost the same as stock.
Old Jul 11, 2009 | 12:20 AM
chaotichoax's Avatar
I'd had my act hdss for 21k miles...I used to get lock out maybe once every 30 or so high rpm shifts
buschur underhood shifter bushing really changed the feel of things and definitely improved the lock out issue...I have had it happen to me once in the last 12k miles and I drive my car hard all the time
Old Jul 11, 2009 | 12:31 AM
evoracingstar's Avatar
yes lock out sucks. but im not going to lie i have easly over 60 launches on this clutch with stock flywheel resurface. and it held up real good! its just starting to slip now. its a very good clutch for the money. the lock out sucks tho im going to have to agree. but this clutch can take a veryy good beating!
Old Jul 11, 2009 | 01:48 AM
nightwalker's Avatar
Something wrong in the install. Just because a mechanic is a pro doesn't mean he knows it all. You have to consider if he knows Evos, and followed the factory Service Manual.
I've had my ACT for 15k miles of daily and hard driving, and it shifts just fine. I did my clutch myself.
Old Jul 11, 2009 | 02:12 AM
skyblas's Avatar
exedy twin clutch is the best bang for your bucks
