fuel injector questions..
Old Nov 13, 2005 | 08:54 PM
adorkableVo's Avatar
Does our car use the Top feed or Side feed injectors? What are the biggest injectors made for our cars and where can I find them? Thanks in advance.
Old Nov 13, 2005 | 10:28 PM
timzcat's Avatar
Top Feed.
You don't want the biggest available, you want the size you need. I can assure you there are larger injectors out there then you really need.
PE, FIC are both popular injectors available with most of our vendors.
Old Nov 14, 2005 | 09:06 AM
05SilverEvoVIII's Avatar
i would say that until you have some supporting mods you will not have a need to even look at injectors
Old Nov 14, 2005 | 09:10 AM
Mike@Forge's Avatar
Originally Posted by 05SilverEvoVIII
I would say that until you have some supporting mods, you will not have a need to even look at injectors!
+1
Old Nov 14, 2005 | 11:19 AM
smokey's Avatar
what is a good brand for 750cc's? Greddy Denzo? any help is appreciated
Old Nov 14, 2005 | 02:40 PM
timzcat's Avatar
PE injectors are believed to have the best idle characteristics over many of the others. Basically any injector can give you 750cc at full pump but it's how well the injector latency and spray pattern is down low. With larger injectors, enough fuel for the application is a given. Drivability is the one thing that is not a given and many people over-rate thier injectors and have horrible drivability but think because the have 1000cc injectors they are cool.
Old Nov 14, 2005 | 02:42 PM
Ev0ikon's Avatar
Even on stock turbo and Meth injection, I saw 98% Injector Duty Cycle. It can't be good is it? :}
Old Nov 14, 2005 | 02:49 PM
SiCKlEyWiKeD's Avatar
for the most part if you have stock turbo then bigger injectors normally aren't needed.
Old Nov 14, 2005 | 02:55 PM
smokey's Avatar
Does Greddy have good injectors?? Or denzo.....what ever it is ?? just curious. Thank you guys for your help.
