im scared...is this normal
Old Nov 14, 2005 | 11:20 AM
diiirk@AwdMotorsports's Avatar
ok i was just checking my car for leaks with a boost leak test kit i made....so i filled it up with 10 pounds..then i got it up to 20 and all of a sudden it just all leaked out of the oil cap thats on top of the head..kinda sounded like popping off a intercooler pipe....cant be good.....wat do u guys think??
Old Nov 14, 2005 | 11:27 AM
Greg K's Avatar
if you're engine is cold when you do the leak test you will have some blowby the piston rings. I would warm it up good before performing the test.
Old Nov 14, 2005 | 11:32 AM
fury656's Avatar
To avoid that cap the UICP before the throttle body when you do a test. That way you're not pushing pressure into the engine.
Old Jul 13, 2006 | 07:39 PM
dsmfan95's Avatar
Bumping an old thread.
I got the same results and my motor was at full operating temperature. I had just got done driving it about 20 mins before. Would that make that big of a difference?
