no boost after manifold install??
Old Nov 14, 2005 | 02:05 PM
rjdEVO's Avatar
ok,, started to install tubular manifold ran into a prob with the bolts coming from the atp turbo hotside,,,to long and were hitting the mani tubes...after that i put the stock mani on and re used the stock gaskets so i didn't waste the new ones,,,after that there is no boost,,,stops after vacuum..i imagine there is a leak in the mani but it shouldn't drop to ) boost,,or is that possible? need some help
searched but nothin specific enough
Old Nov 14, 2005 | 02:09 PM
05SilverEvoVIII's Avatar
start with checking all your connections this is the first place to start with a boost leak then go from there
Old Nov 14, 2005 | 02:11 PM
rjdEVO's Avatar
goin to put the new mani on wed. atp sent me smaller bolts,,,regardless though, the hotside should still create boost even with a leak? or am i wrong with that statement
Old Nov 14, 2005 | 05:21 PM
rjdEVO's Avatar
anybody??? lil help here
Old Nov 14, 2005 | 05:23 PM
SilverEvo8owner's Avatar
you would hear it if there was a problem with a gasket seal
are getting absolutely no boost or is the guage just not reading anything?
Old Nov 14, 2005 | 05:31 PM
rjdEVO's Avatar
no boost at all
Old Nov 14, 2005 | 05:36 PM
EVILutionVIII's Avatar
Veteran: Air Force
Definitely....I've blown two exhaust manifold gaskets and when it's leaking, you WILL know it. Not only will there be soot in the area that it's leaking, but it will sound awful and the leak will eventually get bigger. Check all your vacuum lines to make sure they're connected and free of cracks/holes then check again.
Old Nov 14, 2005 | 05:45 PM
rjdEVO's Avatar
i'll have to do that wed i guess,,,hope its just a loose ic pipe
Old Nov 14, 2005 | 06:54 PM
does it feel any different when you drive it?
perhaps you dropped somehting in the turbine keeping it from spinning?
Old Nov 15, 2005 | 05:57 AM
rjdEVO's Avatar
the vacuum gets to zero but never gets into positive boost, before the mani was on i air hosed the turbine and it spun fine??
Old Nov 15, 2005 | 05:05 PM
where is the boost guage T-ed off? If the car was not boosting, as in the turbo not spinning, you would see only vacuum... more than what you would see at idle. I had my BC T-ed at the fuel pressure regulator and it came off at the regulator nipple. I could read some vacuum but any boost reading would hit only 1 or 2 pounds even though the car was running close to normal boost pressure.
How does the car drive? Does it make any weird noises or anything? Does it pull at all?
Old Nov 15, 2005 | 05:19 PM
dubbleugly01's Avatar
if you're making absolutely no boost, not even 1-2#'s, it's more than a vacuum leak or vacuum hose routing. Your turbo is toast (I hope that's not the case), or you left a intercooler hose/pipe completely off.
Good luck with it, it's probably something with the install that when you find it, you'll be kicking yourself for all the worrying!
Old Nov 16, 2005 | 06:03 AM
rjdEVO's Avatar
well looks like i'll find out today,,, i hope its a ic pipe which i think it is becuase the turbo was spoolin fine before the install
Old Nov 16, 2005 | 06:08 AM
BoostWhore's Avatar
Is your wastegate stuck open maybe?
Old Nov 16, 2005 | 06:10 AM
rjdEVO's Avatar
never thought of that but how would that even happen
