Cat Delete- Resinator/Testpipe??
Want to delete CAT...Will test pipe/resanator, high flow cat give me a check engine light?? Could I use my stock CAT with 3'' down pipe and cat back??
SETH......
zx10
SETH......
zx10
SETH......
zx10
SETH......
zx10
I hope that helps.
Thanks Andrew, thats all i need to know...........for now''''
I've seen some with the o2 hole, so ill go with one of those if I decide....
G.L.O (good looking out)
There's a few posts about using the "Help!" spark plug anti-foul bungs that you can purchase from any auto parts store. I think it's the 18mm units? I did this on mine running a resonated test pipe and so far no check engine light after 2,000 miles. It limits the amount of exhaust gasses the rear 02 sensor sees and prevents the check engine light. You'll need two of them. Drill a 1/2" hole in the second one so the 02 sensor will screw all the way in. Screw the two bungs together, followed by the 02 senor and screw the bungs/02 sensor into the rear 02 bung on the exhaust. Problem solved and all for under $10! Assuming you have a 1/2" drill bit and a drill
