intercooler piping: how much power?
Old Nov 15, 2005 | 07:25 PM
mphevo's Avatar
what are average gains from upper/lower hard kits?
Old Nov 15, 2005 | 07:56 PM
Ultimate CC's Avatar
Lower is only part that you really seen power gains. Upper depending on which you get will help spool up but even that is debated. I would go with a LICP kit first and pick up a small battery and UICP later on. I recently picked up the AMS LICP and a LPI UICP since I want to keep stock battery. If you do a search you will find a ton of info.
Old Nov 15, 2005 | 07:58 PM
Mike@Forge's Avatar
A lower pipe MAY yield 5-7 whp or so at the very most, but spool will be improved by a few hundred rpm's.
An upper pipe doesn't provide as much of a noticeable improvement, but can't hurt.
Old Nov 15, 2005 | 08:18 PM
EVO3675's Avatar
My hard pipes made a throttle response difference and highway power
Old Nov 15, 2005 | 08:21 PM
EvoDan2004's Avatar
do you need a tune or no if you do a full icp set. also adding a biger fmic. thanks
Old Nov 15, 2005 | 08:22 PM
JTB's Avatar
JTB
Only do a LICP if you have supporting mods. It will make no difference and even possibly hurt performance unless you have other items that improve flow -- such as a TBE
