05 MR clutch problems...?
Old Nov 17, 2005 | 08:35 PM
dubbleugly01's Avatar
is it worse when it's cold? worse in reverse? worse in the lower gears compared to the upper gears? If so, it's clutch chatter, and fairly normal. If these are your symptoms, there is nothing really wrong, you'll just need to rev a bit higher and drive around it. An engine torque dampner might help also.
Old Nov 18, 2005 | 02:40 AM
PeteyTurbo's Avatar
I don't think the disc will get glazed over from one moderate launch. My sisters WRX has the same exact problem and every 2 months it chatters again.. It is due to her driving style, too much easy engagement over and over again.. It was so bad that her whole car would shake sometimes..I just do one launch and problem completely solved. I have used this method for many stock and aftermarket clutches over the years and it works, as long as you do it in moderation. Luckily I have had zero problems with my clutch so I've never had to do this on my car and I have over 100 drag passes on it.. As far as glazing the flywheel over, that sounds unlikely because the organic material really never just transfers onto the FW and stays there, if anything, in the worst case you would have hot spots.Where the glazing occors is the disc, its porous material gets clogged causing an unstable friction characteristic as compared to a nice clean disc surface, kind of like when you move a plastic chair back on a linoleoum floor..
Originally Posted by TTP Engineering
That sounds like it would do the opposite. You would actually glaze the flywheel over if the clutch burnt from a launch.
Old Nov 18, 2005 | 02:49 AM
kcross's Avatar
ill be the echo... it happens. first drive of the day, when its cold, if you dont rev up enough, if you dont let the clutch out correctly. im no mechanic but i dont think its a big issue.
Old Nov 18, 2005 | 03:35 AM
Assassin's Avatar
It happens on mine too. I noticed it's from accidentally slipping the clutch and not just releasing it. I don't have an MR BTW.
Old Nov 18, 2005 | 04:37 AM
nirvevo's Avatar
If the symptom happens mostly when things are still cold, removing the restrictor might be the right idea.
If the fluid moves slower because it is cold, and the restrictor's job is to slow down the engagement of the clutch, it would follow that once the fluid warmed up, the symptom would go away. It could still happen after things warmed up because of the restrictor, maybe just not as easily.
My other car has only had the clutch replaced once in 180K. It's a 4 wheel drive and I showed it NO mercy (Drove it like the TV commercials)
My Evo's stock only lasted to aprx 27K, and I babied it.
Removing the "pill" is pretty easy. I regretted not doing much earlier. I didn't do it till, I think, around 20K. Should have done it the first week I had the car.
Good Luck
Old Nov 18, 2005 | 09:15 AM
MrEvoVIII's Avatar
Originally Posted by Mark Sebby
How many miles?
it's at 9200 miles right now....
The funny thing is when it was new
in Dec. 04, there was already a very slight sign of it around
the 10 mile mark...
Old Nov 18, 2005 | 09:21 AM
MrEvoVIII's Avatar
Hey guys, thanks for the input. It's comforting to hear
that I'm not the only one. Still sucks nonetheless, b/c I
baby the damn thing....the WHOLE car shakes when it
happens!
But yeah, it's mainly when it's cold;it does it only in
1st gear, and does not happen when goin into
reverse at all.
Old Nov 18, 2005 | 09:39 AM
silverghost's Avatar
MR clutch chatter
This is usually a combination problem between the pressure plate surface and the clutch disc. You might try driving for a day or two intentionally down shifting (gently) every time you need to decellerate to reverse the engagement torque loads and if you are lucky refresh the surfaces of the clutch disc and pressure plate. If this does not remove the chatter you are probably looking at a clutch job and flywheel resurfacing. Unresolved chattering usually gets worse as the chatter patterns are built up on the pressure plate, clutch disc and flywheel. If you need to replace the clutch strickly follow the breakin recommendations which usually means no hard starts for 500 miles or more. Lastly, do not ever "hill hold" with the clutch. You are just begging for problems and short clutch life when you do this.
Old Nov 18, 2005 | 10:52 AM
evonsx's Avatar
I have 11,000 miles on my MR and mine does it when it is cold. Believe it or not, I have never done a burn-off.....yet. When it worms up the problem goes away.
Old Nov 22, 2005 | 03:02 PM
MrEvoVIII's Avatar
Yeah, I was thinking that the clutch or flywheel surface had been warped, but that doesn't explain the nice and even exgagement when the car warms up... so i guess it's not the surfaces that's the problem...? or is it...? hmmmm.
