Is anyone else getting 1st gear shutter when taking off from a stop?
Old Dec 2, 2005 | 07:05 AM
Smogrunner's Avatar
Yeah I get it too. See sig for mods. I wonder if I may have a damaged or broken motor mount that could be adding to the shudder.
Old Dec 2, 2005 | 08:17 AM
dubbleugly01's Avatar
Most of the standard tranny cars I've driven had some sort of mild stutter, especially when cold. My evo started doing it on the stock clutch, and has been doing it since about 10,000 miles (now at 42,000).
Try reading up on the ingall's stiffy review thread here on evom. I put one in to help with high rpm shifting issues (which it did help), but it also practically made any and all stutter go away. Assuming you didn't smoke your clutch and have big globs of friction material all balled up on the clutch facing, an engine dampener could help.
Old Dec 2, 2005 | 09:18 AM
sno_evo's Avatar
well its just i didnt notice it at first, but now i do.... but if multiple people are expirencing it with similar mods, im not scared.
Old May 8, 2015 | 09:24 AM
KeNx242's Avatar
I have the same shuttering issue, it is only in the rear end though. Suggestions? I just recently bought the car.
Old May 10, 2015 | 06:00 PM
barneyb's Avatar
The clutch that came new in my car would do this. The trouble was the clutch lasted 90K. I replaced it with another OEM clutch. Maybe OEM but not the same clutch. This one is sweet.
Old May 10, 2015 | 06:04 PM
KeNx242's Avatar
Would your shutter only be in the rear end?
Old May 10, 2015 | 06:16 PM
barneyb's Avatar
It was the clutch.
The only time you should get a shudder in the rear end is if turning and the gear oil in the differential needs friction modifier. Yeah, I know they stacked the USDM differential plates so as not to work but sometimes they do anyway.
Old May 10, 2015 | 06:19 PM
KeNx242's Avatar
Alright, i got a JDM evo 8 lol.
Thnx for the help though, will have to change soon i guess.
Old May 11, 2015 | 12:00 PM
barneyb's Avatar
A little chatter in the rear from a properly working plate type LSD does not mean something is wrong. Go watch the WRC cars and notice the racket they make.
Old May 11, 2015 | 12:02 PM
KeNx242's Avatar
Its not a little.. i have the rear diff bushings on order so hopefully that will help.
Old May 11, 2015 | 12:09 PM
barneyb's Avatar
Do you know what oil is in there? If not, the easy solution may be some Diagueen.
RED DEMON
18
Jul 27, 2015 06:38 PM
Joes06MR
14
Sep 14, 2007 03:45 PM
Lancematic
Feb 10, 2007 12:35 AM
05silevo
Sep 30, 2006 05:00 PM
Deceit
Apr 24, 2004 11:28 PM
