AVO S-Type Turbo Kit Installed
Old Nov 22, 2005 | 06:49 AM
Pd1's Avatar
Pd1
Originally Posted by NOLIMITMOTORS
PS ANY WAY I CAN BUY JUST THAT MANIFOLD???
I'd say it's possible, but you'd have to ask AVO to be sure. Cast is heavier, and not equal length, but you don't have to worry so much about it cracking from water droplets or antilag bursts. Also, it's pretty stealthy with the stock heat shield.
Old Nov 22, 2005 | 07:10 AM
04 rs's Avatar
how much was the whole kit??
Old Nov 22, 2005 | 07:24 AM
Evo23IG's Avatar
I believe its $3500 like its says on the website. Would love to see how this compares to 50Trim turbo or GT3071R. Definately looks like a great kit, congrats.
Old Nov 22, 2005 | 10:58 AM
RnR Racing's Avatar
Looks good. The only problem I have heard from the AVO kit is the manifolds cracking. We have a customer on here that cracked 2 manifolds in a short period of time.
Old Nov 22, 2005 | 11:01 AM
04 rs's Avatar
$3500!!!!!!!! and it comes with a cast manifold and internal gate??
Old Nov 22, 2005 | 11:02 AM
Evo23IG's Avatar
Wow, cracking a CAST manifold is pretty tough. I guess everything is possible.
Old Nov 22, 2005 | 11:04 AM
Evo23IG's Avatar
Yes, here is pic of the whole kit.
Old Nov 22, 2005 | 08:40 PM
Pd1's Avatar
Pd1
I didn't actually have to pay retail since I bought the cat-back exhaust at the same time. Depending on the location of their stock (Australia, Japan, or CA), and how much you purchase at once, there's a chance they'll work with you on price.
Evo23IG: Actually, that picture doesn't show everything in the kit. The pictures that I posted in the beginning of this thread show all the pieces included.
RNR: No need to downplay a competitor's kit in this thread. Coming from a vendor, a comment like yours will be read with skepticism. Everyone who reads anything in this forum knows you guys have your own issues with your manifolds. Simple logic should allow anyone to realize that a welded tubular manifold will crack (generally) long before a cast manifold; hence the use of cast manifolds by OEM for ages.
Update: Dyno figures will be posted in this thread on Saturday. I'm going to see Nick at Precision.
Old Nov 23, 2005 | 08:45 AM
wingless's Avatar
Great write up! I have often wondered about this kit. I look forward to seeing how this works out for you.
It looks a lot like the Owen racing turbo from the FQ also rated at 450hp. Check out this link and see if any of the details look similar. How cool would that be if they are same/similar at that price. The Owen below is crazy$$.
http://www.owendevelopments.co.uk/p...o-products.html
Old Nov 23, 2005 | 08:50 AM
wingless's Avatar
Link sucks... try this, go to evo turbo... http://www.owendevelopments.co.uk
Old Nov 23, 2005 | 10:48 AM
RnR Racing's Avatar
I am just stating what happened to our customer. I like the look of the kit and I wasn't bashing anyone's product. For the record we have only had one defective manifold out of 200 built to this date.
Old Nov 23, 2005 | 12:34 PM
Chris@nolimitmotors's Avatar
jesus christ, 3500$!!!! WOW, i woulda bought the Buschur kit
Old Nov 23, 2005 | 05:48 PM
silverofs's Avatar
looks good man hope it works out for you..
i also came from the dsm background/dsm link good to see you are using it how is the small stuff working like keyless entry ect.. are you using the evo maf, blowthrough ?
i looked into doing the switch over but i just went to the aem instead.. i'd like to see your dyno numbers when you get them..
Old Nov 24, 2005 | 12:35 AM
Pd1's Avatar
Pd1
Thanks, Wingless. Yeah, I looked into the Owen Developments kit, and they are similar in that they use a cast manifold and O2 housing which look a lot like mine. However, the turbo in on the Owen website looks a good deal different from mine. It certainly is a different compressor and exhaust housing. In the end, they probably perform similarly...though I can't say for sure.
Another similar kit to keep in mind is the one from APS. Good luck finding it, though...as they are no longer in production (for now, at least). Pics are on the APS website. As both APS and AVO are in Australia, I would think they're utilizing some of the same raw materials.
Old Nov 24, 2005 | 12:41 AM
Pd1's Avatar
Pd1
Keyless entry works fine even with the ECU unplugged from the car. I'm using the stock Evo MAF. The ONLY issue, and this is minor, I have is that my primary fan runs all the time instead of cycling. Other than that, the differences are that the fuel pump runs at max instead of switching from low to high, the smart-key encryption is removed (stored in the Evo ECU), and the Auto IC sprayer doesn't work (Manual does). Everything else is fully functional. I won't tell you that the car always runs as perfectly as the stock ECU, but if a stranger were to drive it, he/she wouldn't know the difference. AEM is also a great choice, and I'm sure you'll be happy with it.
