AVO S-Type Turbo Kit Installed
Old Dec 17, 2005 | 10:10 PM
  #31
Pd1's Avatar
Pd1
I probably should have posted my dyno/update into this thread instead of my exhaust thread...oh well. Here it is!
https://www.evolutionm.net/forums/sh...=167708&page=3
On this turbo kit, AVO is going to make another downpipe that (they claim) clears the crossbars. I'm not sure they knew that their turbo-kit downpipe wouldn't clear (their downpipe for the stock turbo does clear). For those of you wondering, yes, they are going to send me another one to replace mine .
As for the missing gaskets, I'm not running any between the turbo and manifold, or between the O2 housing and the downpipe. No leaks! Since I made mention of this to AVO, they shipped me out some gaskets to make me feel better. Even though I don't need them at the moment, it was really good of them to ease my concerns that way. AVO is a top-notch company, if you hadn't gathered that by now.
Old Dec 17, 2005 | 11:12 PM
  #32
mchuang's Avatar
Originally Posted by Pd1
Keyless entry works fine even with the ECU unplugged from the car. I'm using the stock Evo MAF. The ONLY issue, and this is minor, I have is that my primary fan runs all the time instead of cycling. Other than that, the differences are that the fuel pump runs at max instead of switching from low to high, the smart-key encryption is removed (stored in the Evo ECU), and the Auto IC sprayer doesn't work (Manual does). Everything else is fully functional. I won't tell you that the car always runs as perfectly as the stock ECU, but if a stranger were to drive it, he/she wouldn't know the difference. AEM is also a great choice, and I'm sure you'll be happy with it.
Dam so that mean you probably can run a hks vpc also if someone were to develop a conversion harness or something. Did you have to swap over cam angle sensor or something.
Old Dec 18, 2005 | 06:31 AM
  #33
Pd1's Avatar
Pd1
All of the mods were made to the patch harness. All the wiring under the hood is stock. I'd say anything you can run on a 2G ECU is possible with the Evo.
Old Dec 18, 2005 | 07:42 AM
  #34
gunzo's Avatar
Originally Posted by NOLIMITMOTORS
yea he must have switched over to that ecu, i'm sure the wiring was fun.
PS ANY WAY I CAN BUY JUST THAT MANIFOLD???
yes you can..
you'd flip if you know the price!!
FYI.. the cracked manifold issue was due to poor tuning.. been running that manifold for more than a year and a couple of trackdays..
Old May 15, 2006 | 02:36 PM
  #35
Rich@Orbital's Avatar
Quick Questions..
Can you utilize an aftermarket downpipe (other than the AVO) as you can with the Owen Developments Kit?
Is the O2 Housing a true 3" piece?
Any idea what kind of turbocharger assembly is included with the R-Type Kit? I've been very interested in a 50-Trim for some time now, but don't know where else to look besides AMS, TT, and Shearer.
It's absolutely amazing how similiar the AVO system looks by comparison to the Owen Developments. I was/am very interested in the APS, but I can't seem to obtain definitive information/pricing on their kits.
Thanks in advance!!
Old May 15, 2006 | 04:18 PM
  #36
Pd1's Avatar
Pd1
Originally Posted by Rich@Orbital
Quick Questions..
Thanks in advance!!
Hi Rich. (I actually met you one night out in NJ and bought that one tire from you if you recall..)
To answer your questions:
1.) I don't believe you can use any other downpipe with this kit because it is custom, though I'm not absolutely positive about this. I actually have two (both full 3" SS). One with a few bends that easily clears both stock bars, and another with minimal bends that doesn't clear either bar. Both downpipes utilize a flex section.
2.) Yes, the O2 housing is true 3".
3.) Sorry, I don't know which CHRA they are using in the "R" kit. However, I did learn that they are using a 3076 -18 in mine. This is a 50lb/min turbo (~500hp) per Garrett.
It's funny you brought this thread back up today. I'm actually considering going a different direction (i.e. stock to sell) with the car and may be putting this kit up on the market, although I've loved this setup.
Old May 16, 2006 | 08:43 PM
  #37
Pd1's Avatar
Pd1
This kit is now available for purchase: https://www.evolutionm.net/forums/sh...d.php?t=201355
pwerks
38
Sep 21, 2009 08:42 PM
Pd1
Aug 2, 2007 06:03 PM
EVO-6.5 (KSA)
21
Apr 24, 2005 10:10 AM
Evo8Master
18
Jan 8, 2005 11:01 AM
inariv5573
Feb 23, 2004 10:04 AM
