Boost leak test, gone bad!!
Its delivering a constant volume of air to maintain that pressure, if you dont block upper i/c pipe off @ the air will escape through open valves etc. If he turned the engine to tdc I doubt he would lose as much if any air, it's just easier to block off the upper i/c pipe @ the tb.
ok tried to block of the t/b, the problem is that with the t/b blocked the tester does not pressurize any of the vacumm lines, so how can do a 100% leak test. also already tried TDC and air still escaped.
** I have done this test 3 or 4 times before and the lines all pressurized w/out blocking the T/B... I am so confused
honestly we think the air is escaping past the wastegate flapper due to inproperly seating. just really weird it has worked perfect in the past. the symptom we are having is unstable idle when coming to a stop with a flash of the oil light....then stalling. any ideas.......? weird
Well, I would say break it down into sections. Cap at the spot where the lower IC pipe meets the fmic and try it. If THAT leaks then it's in the turbo outlet and connections up to the FMIC. Then cap at the other side of the FMIC or halfway thru the upper IC piping ... break it down into sections. If you're cool from the turbo intake to the TB then you're golden. If not, a hose is not connected somewhere. Your MBC and BOV must be in place, don't forget ...
I'm no pro and have little time at this but these are my thoughts... good luck!
what was the last thing u loosend around ur intercooler pipes, check them. instead of check all these other things, think of things u have modified and maybe became loose over time. recheck them and go from there.
motor was cold
Something simple, crank the motor so that the valves find a new position and try again. Maybe the motor just stopped at a convenient place that has a bit of intake/exhaust valve overlap on one of the cylinders allowing all your test pressure to work it's way through the engine. Find a new resting spot and it may take care of itself.
If you think you have a hurt motor, ring blow by would pressurize the crankcase and it wouldn't be coming out of the tailpipe. A bad pcv valve would do the same.
A bent/burnt valve would cause it to come out the tail pipe. An open egr valve would do the same. Does anyone know the "resting state" of the egr valve with no power to it? If it is open, then turning the key on to supply juice to the egr relay may close it while doing the test.
