HFC question
Old Nov 23, 2005 | 02:09 PM
supravital's Avatar
HFC question
i have a megan tbe on order and should see it soon..as all of you know it comes with the test pipe...well i def. will use it for track days, but dont want to risk getting pulled over with it and end up wit a huge fine...what is the best hfc out there with a resonable price....also does an hfc throw a CEL??...i would def want one that doesnt throw any kind of CEL...thanx
Old Nov 23, 2005 | 02:15 PM
djmikeymike's Avatar
UR HFC is the best from what i have read.......... and i did throw a CEL untill i did the sparkplug anti-foul trick
Old Nov 23, 2005 | 02:17 PM
taenaive's Avatar
HFC is also illegal. Usually cops won't ask you if you have a cat or not. They don't seem to care unless they see the fire spitting out of your exhaust. But you can still tell them you have a cat. And they will give you the ticket to go the smog referee. Then, you put everything back to stock and go pass the test!
oh, yeah, HFC throws the cell too .... about once a month.
Old Nov 23, 2005 | 03:05 PM
Gruppe-S's Avatar
Hi,
A good high flow cat should be metal-substrate. It will out flow the old style creramic cat and last much longer. I am using the Helix 3" HFC with a cel fix without and SES light.
FYI, I had another brand of 3" ceramic HFC on my car before and I actually lost power but lets not get into discussing who's cat.
The Helix Hi-Flow cats are the optimal system for the performance minded EVO owner. This particular high-flow cat incorporates a 200 cell Metal-Substrate high-flow catalytic converter and thermal barrier heat-shield. The thermal barrier heat-shield assists in rapid warm-up of the cat for maximum efficiency and helps to keep exhaust gas velocities high.. Piping diameter is 3 inches and includes all necessary hardware for trouble free installation.
Hope that helped.
Thanks,
Tom
Old Nov 23, 2005 | 03:11 PM
Aby@MIL.SPEC's Avatar
car sound cat 94209 ordered from performance peddler ~$60.
you'll need 2 flanges & some pipe to make it a usable piece. get them from rre.
great power, no ses light in my experience.
or buy a rre rally cat, not sure about ses, looks like a cat, make big power=resonated test pipe.
good luck
Old Nov 23, 2005 | 03:13 PM
inariv5573's Avatar
I was also searching for a HFC that wouldn't throw a CEL. But there were none that would guarantee it and I don't want to go around it by doing a CEL fix. So I decided to stay with the stocker, HKS downpipe and AVO catback. If I really need to go high flow, I will do Magnaflow. They are EPA and LEV certified as well as CARB approved. They are great as replacements as they are OBD2 compliant.
Old Nov 23, 2005 | 06:53 PM
marksae's Avatar
I can attest to the power gains of the metal substrate cat over the ceramic. Only downside is that my exhaust smells like I have a test pipe at idle sometimes. I also get a CEL every once in a while. No biggie to me.. I just clear it w/ my scanner.
