Adding External Wastegate to Megan Manifold
Old Nov 23, 2005 | 05:15 PM
joeymia's Avatar
I got a good friend who is good at welding. I would like to add a external wastegate to my megan manifold. Has anyone done this before with this particular manifold? Do I just cut the front two runners and add the wastegate there?
Old Nov 23, 2005 | 05:28 PM
RnR Racing's Avatar
To do it properly you need to come off both ports of the manifolds because it is a twin scroll. It can be done though.
Old Nov 23, 2005 | 05:30 PM
joeymia's Avatar
so combine one of the rear and one of the front runners?
Old Nov 23, 2005 | 05:45 PM
joeymia's Avatar
So the wastegate goes to the 2 runners in blue correct?
Old Nov 23, 2005 | 06:04 PM
RnR Racing's Avatar
yes
Old Nov 23, 2005 | 06:06 PM
joeymia's Avatar
yes
thanks
Old Nov 23, 2005 | 06:20 PM
MANGOOK's Avatar
Here is a picture from member Randy
Kit contains:
DNP Header with Custom Work for Tial 44mm External Wastegate
Dump Tube
2005 EVO 10.5 Hotside with custom work
Old Nov 23, 2005 | 07:16 PM
Randy's Avatar
Thanks Mangook!
Yes but in order to do this you must do the following:
Weld shut your hotside wastegate flapper.
Take the Megan Manifold and since our turbos are twin scroll you MUST do this process carefully to take ALL 4 runners of the manifold and your friend does the magic with the welding doing what is needed. I suggest a 44mm Vband wastegate from Tial or ANY vband wastegate, why? Because its easier to remove. Also the dump tube if you do it properly will travel directly behind the A/C compressor and with the proper angle it will go after the undertray so you dont have to cut it.
Hope this info helps and happy power gaining because it will make some power on your car.
Old Nov 23, 2005 | 08:44 PM
joeymia's Avatar
Originally Posted by Randy
Thanks Mangook!
thanks!
sparky
20
May 31, 2008 08:34 AM
KillaItalian904
May 29, 2008 12:05 PM
gunnerman
Apr 13, 2006 11:06 PM
gunnerman
Mar 2, 2006 12:10 PM
joeymia
Sep 12, 2005 01:30 AM
