Freeze plug popped out
Old Nov 24, 2005 | 12:02 PM
USAF_STi's Avatar
So last night at the drag strip i was on my final run, when all of a sudden i hit fuel cut. so i pull around i pop my hood. Low and behold there was coolant everywhere. after searching around i found the freeze plug on the water pump popped out. do you think i need a whole new water pump? or just to replace the freeze plug? thanks in advance for the help and happy thnksgiving! Brett
Old Nov 24, 2005 | 12:52 PM
AdamJ39's Avatar
new pump...water pump is to be covered under warantee from mitsu in a service bulliton...
-Adam
Old Nov 24, 2005 | 12:53 PM
7rider's Avatar
how many cars has this happened to?
Old Nov 24, 2005 | 01:37 PM
USAF_STi's Avatar
-Adam
Thats what i was thinking too. i am modded but it should still be fixed if it is a TSB correct?
Old Nov 24, 2005 | 07:31 PM
AdamJ39's Avatar
2 Freinds of mine had there plugs leak, one had the dealer replace it...and the other didnt bother tring...the dealer should replace it...give it a try... the dealer replaced the timing belt free as well...and both cars were obviosly modified...but then again, every dealer is different ...
-Adam
Old Nov 24, 2005 | 07:54 PM
MrSpeedDemon's Avatar
Ouch, try the dealer
Old Nov 24, 2005 | 07:57 PM
Evoryder's Avatar
dealer
Old Nov 24, 2005 | 08:22 PM
EVIL_EVO_VIII's Avatar
Dealer, mine went too. Got it replaced under warranty no questions asked!!
Old Nov 24, 2005 | 09:00 PM
USAF_STi's Avatar
I will call them tomorrow and schedule an appointment. thanks guys
Old Nov 25, 2005 | 09:52 AM
fimotorsports's Avatar
I had a freeze plug pop out in 4th at the track as well... got it replaced and hasn't popped out on me since.
Old Nov 25, 2005 | 10:04 AM
USAF_STi's Avatar
So you didnt replace the entire water pump? just replacing the plug will work? because the plug is a cheap part and i would not have to mess with the dealer.
Old Nov 25, 2005 | 10:12 AM
mac_05evo's Avatar
same thing happened to me, I just replaced the plug a couple of days ago and it is doing fine so far...
Old Nov 25, 2005 | 11:40 AM
USAF_STi's Avatar
What did you determine as the cause?
Old Nov 25, 2005 | 12:49 PM
Doogie Howser's Avatar
Do the IX have this similar problem?
Old Nov 25, 2005 | 12:58 PM
mac_05evo's Avatar
I'm unsure but I believe I hit fuel cut also and it happened... I was on the car then in 4th gear heard a super loud pop, pulled over, popped the hood and there was the big hole in the back of the water pump where the freeze plug had popped out..
I'd like to know what caused it myself though and hopefully the new plug will stay in there fine...
