guess this part on the T-Case
Old Nov 24, 2005 | 03:11 PM
Sap12687's Avatar
http://www.teamrip.com/images/EVO%20...20T-case-9.jpg
what functionality does the small white "knob" serve that sits on top of the t-case?
Old Nov 24, 2005 | 03:20 PM
en1gma19's Avatar
It's just a plug to keep the hole closed preventing anything from getting inside. You take it off before installing the TC.
There's one at the end too.
Old Nov 24, 2005 | 06:41 PM
Sap12687's Avatar
are you sure youre talking about the same piece as me? not the white ring on the side of the diff...the other one at the top-middle
Old Nov 24, 2005 | 06:44 PM
7rider's Avatar
its a breather
Old Nov 24, 2005 | 08:04 PM
Sap12687's Avatar
oil is leaking out of mine...
Old Nov 24, 2005 | 08:50 PM
timzcat's Avatar
Sounds like it is overfull then? Did you just change or have the fluid changed?
Old Nov 24, 2005 | 09:00 PM
Sap12687's Avatar
yea i changed the fluid about 500 miles ago when i replaced the cluch. Is it just going to bleed until its at an ideal level?
Old Nov 24, 2005 | 09:09 PM
timzcat's Avatar
You should remove the fill plug and see what the level is/let it drain down to the proper level.
Evo47
Jun 15, 2016 07:38 PM
OneCrzyEvo21
May 25, 2016 12:41 AM
Migsubishi
Apr 25, 2016 08:43 PM
steinvb12
Feb 12, 2016 09:18 AM
Ian0611
Dec 17, 2015 02:27 PM
