How can i get 350 - 370whp?
[QUOTE=jesterEVO]ppl told me adding an intercooler on stock turbo wont make much of a difference?
now this is a lie i got about 15 hp out my intercooler on stock turbo. it all depends on your tune like a said before you need a better tune.
Originally Posted by jesterEVO
yeah Al did it..but i had that boost leak...could of been better...would a O2 houseing and manifold do it?
nope still havnet done the boost leak check..i am sure its around the IC kit ..maybe a t-clamp not tight enough ..dont know...i dont know how to do a full boost leak inspection....yeah but a 02 housing and ex mani do me over 350whp...hell i should of been around 330 whp now
Originally Posted by tke_413
It'll definately help. The manifold won't do a WHOLE LOT, but adding that AND a larger o2 housing will give you a nice little gain. Other than that, if you want to see those number jump up...either do alky or run race gas. I'm sitting at about 355WHP on pump gas and the numbers in my sig are with a little bit of 104 gas mixed with 93 and the boost turned up 2 psi. With new plugs and some 110 gas I can turn the boost up some more to hit even higher numbers when I go to the track.
I want the numbers achieved without puting anything over 93...meth kit sounds cool...just scared of it running out of meth and going boom
is the power from the alky constant or at certain points
You won't need race gas once you have an alky kit. It will be like running on race gas all the time, and it should get you closer to 370whp than 350whp as long as your tune is good and you remedy the boost leak.
You should be reasonably close to that, with alky and a retune you will definitely be in the upper range of your goal. Font mount will help but is not necessary. I believe they can tune it by mail for adding alky. Thats what Mark (TurboTrix) told us last week when they were down here.
