How can i get 350 - 370whp?
I think your first priority is fixing the boost leak and figuring out why your car is down about 25-30 whp compared to other 05's with similar mods.
You also might want to check the BOV to make sure it isnt cracked, in addition to the IC pipes. It might not be a bad idea to upgrade to a JDM MR bov if your going to be running higher boost on meth.
Once you get your car sorted out on pump, then turn on the meth/water and get it tuned.
Also, figure out exactly what you want out of the car. 350 whp is sort of a threshold number, in that you can get pretty close to it on the stock turbo on pump gas. 370 whp almost always requires significantly higher than stock boost levels and race fuel or meth/water injection.
cool...yeah i hear ya....i will need to find a performance shop to check my boost leak...i have no clue how to check ...car holds boost steady at 21 psi...spikes to 22 ever so often but thats normal with a mbc...then i will have to wait another 25235 weeks for al to get close to NC again..lol i might get the kit now install it...before hand get the boost leak checked out..dont want to take it to mits...there goes my warranty
lol
lol
My goal is to get 365whp at least out of my ongoing setup on 93oct. The last time I was at the dyno I made 346whp with an old-school Hallman which was only holding 17.5-18psi at redline. I replaced that soon after and its been holding much better.
Also, since then Ive gotten the BR FMIC/piping, DC tubular mani, Helix 02, and ported 10.5. All exhaust parts just listed have been ceramic coated as well. I have only installed the DC mani out of the bunch but my car is making great power.
As a bad comparo.. I know I know... I raced a recently tuned car (yesterday) today who made 352whp. I pulled it 2 times from 3rd gear roll-ons. I would only assume Im definitely making more than 352whp, enough to pull away from one who just dynoed that.
Anyway, Ill be back on the dyno when I get my ported/coated hotside back and my 02 then going back for a retune since my car is running quite rich.
my buddy is the other evo soon2BEVO raced...he's got an 03 and he's basically got the same mods as you cept he's got a ported hotside, non ported helix o2 housing, maxford header and lower IC piping...i think once you fixed your leak and put in a ported/coated header, o2 housing, and port your hotside, you'd hit around 370 on pump gas...
Originally Posted by jesterEVO
any way to get this HP with out an alky kit?
is a re-tune needed after this ?
If it was an off the shelf flash, you should be ok and probably pick up power as the off the shelf flash doesn't have a boost leak programmed into it, and you're currently running pig rich. But if it was a custom tune like you say, and Al was tuning to the limits on a/f and timing, you might actually lose power after you fix the boost leak by running too lean and timing being pulled.
Al said my boost leak was small. He said it wasnt that bad. But that 318whp was all he could muster out of it. He said if i get it fix i should be fine. Well i hope he
is right!
is right!
