Look's like my luck has run out!
Old Nov 26, 2005 | 01:30 PM
LIFER's Avatar
Unhappy Look's like my luck has run out!
Well I noticed there has been alot of vibration coming through my clutch pedal, So today while pulling into my garage to change my oil i felt grinding in the pedal.
While the car was in gear and holding the clutch in i reved to like 5k rpm's... Thats when I felt it, Felt like metal hitting metal... Please break the news to me softly, what is wrong with my car.
-checked tranny fluid its fine.
-update- the grinding feedback I feel in the clutch pedal can be felt when I rev past 3k rpms even when the car is not in gear. You can also hear the the grinding, its very similar to the grinding sound you hear if you would try to shift w/out the clutch being fully eganged. It is most noticable from 3-4k rpms... When standing in front of the car it seems to be coming from the left side of the car in the lower region. compession check was good, and when I drained the oil there was no shavings in it.
__________________
Old Nov 26, 2005 | 01:32 PM
WrX Kila's Avatar
Did you try to move the car?
Old Nov 26, 2005 | 01:55 PM
LIFER's Avatar
Yes it drive's... I just fell the grinding, it is most noticable when at a stop and reving
Old Nov 26, 2005 | 02:18 PM
DragNRacing's Avatar
Sounds like it could possibly be your throwout bearing/clutch/flywheel. Does the noise change if you have the clutch in versus out?
Old Nov 26, 2005 | 02:21 PM
vboy425's Avatar
does the noise stop when the clutch is press?? sound like your driving train is done "Synchro"
Old Nov 26, 2005 | 02:22 PM
soundfx007's Avatar
Probly TOB
Old Nov 26, 2005 | 06:58 PM
LIFER's Avatar
The grinding is still there with or without the clutch in... when I rev it grinds....
Old Nov 26, 2005 | 07:28 PM
Most likely not your TOB then.
Old Nov 27, 2005 | 06:29 AM
LIFER's Avatar
Doe's anyone have any idea's... Looks, like I'm going to have to go to the "stealer". These are the time's I wish I was not moddd so my warrenty would cover this
Old Nov 27, 2005 | 07:51 AM
vtecwrecker's Avatar
if it grinds when you rev it out of gear than i dont think its trans related.. sounds like you have a problem in the lower end, or maybe even the head. could even be something in the pulley system.
have someone rev it out of gear while you try to figure out exactly where the noise is comming from. that will make it easier to figure out.
also put it up on jack stands and see if its coming from the oil pan.
Dann
May 15, 2025 06:16 PM
heel2toe
30
Mar 15, 2016 12:54 PM
MarkChamorro
Jul 14, 2012 10:20 PM
bigjhoney
11
Sep 5, 2005 11:30 AM
I REP 838
Feb 26, 2004 03:53 PM
