Recently Dynoflashed w/ Alky Kit
Originally Posted by fuzzychi
Try going to Start->Run
Type in cmd
Press Ok
then type ipconfig /flushdns
Press Enter
And see if you can see the picture.
Type in cmd
Press Ok
Press Enter
Originally Posted by justchil
Did you happen to have Dave print out a graph of ur boost curve/afr etc..?
This was done in case the alky failed so that my engine would still a chance, I think also since I had the older alky kit w/ larger nozzle they couldnt get the AFRs leaner because of the larger nozzle.
I'm not sure if this could be problem? I actually only have the Injen I/C piping and not the full kit which includes the Intake Pipe and Filter.
Could the way I am routing this be the problem?
Here are some pictures of it:
I doubt the UICP has anything to do with it, I bet the stock BOV has a big part. You won't ever know what kind of power the car is truly making till you bring it to the track.
Originally Posted by Ultimate CC
Yea stocker doesn't really hold well past 18psi
Why would Mitsubishi put a BOV that can't hold 18psi when is supposed to hold 20.3psi in stock form? Don't get me wrong, I dont like that cheap plastic BOV and I'll have to ditch it once I get a AI kit, but for now it works just fine.
There are several members who have tested it and it begins leaking at 18psi, don't ask me why Mitsu did this. Does anyone wonder why the EVO9 now comes with the JDM MR BOV? Just my .02
Originally Posted by chmodlf
Does your EVO really weigh 3625? WOW that seems heavy.
That must have been with the driver???
I wonder if more weight in that column makes the resulting hp/tq numbers lower?
