Recently Dynoflashed w/ Alky Kit
Originally Posted by madpacket
Ever since Buschur got the Mustang dyno it has been showing 3625. I think they just transposed the 6 and 2. When I dynoed on a different MD they listed the weight was 3265 which is much closer to the mitsu-claimed weight.
I wonder if more weight in that column makes the resulting hp/tq numbers lower?
Oh yea, to the OP, your numbers seems low. My car was dynoed 232/233 (semi stock, only panel filter and JDM MR DV) on a MD that had no specs tampered with it and used the car weight and HP@50MPH MD says to use. But... I have a JDM MR DV...maybe you sould look into a new DV
A few points
I wish we had just changed out your bov ! I think they were out of stock on forge bov
Second - the dyno does read low - but your power was low also
With boost falling down with leaking bov the turbo works harder to make desired boost and the back pressure increases - it becomes more and more difficlut to make max power
Third - with alcohol 90 % of the power comes from more boost which you cant do with a leaking bov
Fourth - dont comapre dyno numbers - your pre - tune and post tune sheet shows the gains from the tuning alone with same parts
IF YOU change the BOV and turn up the boost you will pick up more power
Next time I am at Buschur I will recheck it for free for you and see how much power you are making with a good bov
NOTE - ALL stock bov's do not leak - some work great - others leak
The car was tuned reliable and smooth - a few more whp will come with more boost !
yes, the only thing that matters with dyno numbers is the before and after tune numbers that al has mentioned. PEOPLE, stop looking at dyno numbers trying to compare it to your car. it doesnt work unless u're both using the same dyno, and hopefully it is a consistent one.
do u have a dyno sheet of ur original numbers fuzzychi?
ok, once u get ur new numbers be sure to post them for us all to see!
Originally Posted by Ultimate CC
There are several members who have tested it and it begins leaking at 18psi, don't ask me why Mitsu did this. Does anyone wonder why the EVO9 now comes with the JDM MR BOV? Just my .02
bernardo
141
Jun 16, 2006 06:19 PM
Nvr2old32
81
Mar 9, 2006 08:47 PM
Warrtalon
72
Jan 24, 2006 04:50 AM
