best downpipe and test for money
Looking for a down pipe and test pipe just looking to see what you you. I was looking a HKS but I was thinking there is a better one out there for my buck
I don't know if we are allow to display the vendors names but if you want me to help you out, just send me a pm and I will tell you who sells them that cheap
Yes, but any one-piece design will cause trouble if you ever just want to slap the cat back in real quick for inspection/legal/emissions reasons. You can't do that with a one-piece; you have to replace both the dp/tp each time. If that's not a problem, then the one-piece units are good for you.
Originally Posted by Ultimate CC
Yea I forget about other states but in NY we only have to make sure we throw now cels and we basically pass, there are no sniffer tests.
Yea I guess it depends where you go but most places near me (lower NY) don't ever bother. I ran no cats on suby for 2 years and now my EVO and so far so good as far as inspection goes.
All Test pipes are the same as long as the ID is the same.
A 3" Testpipe made by Megan racing will not flow any less then a 3" pipe made by Buschur or Amuse.
The only thing that the Alloy of the pipes has an effect on is resistance to corrosion and weight.
Now if one had hi temp coating and one didn't then the one with the coating would have the advantage.
