nitrous question
Old Dec 4, 2005 | 06:16 AM
  #31
DSMotorsport's Avatar
Originally Posted by mrcox
And as always i recommend a Nitrous Express kit. The horsepower is rated at the wheels unlike the NOS kit which rates it at the crank.
How the HP is rated on the chart makes no differance in actually using the kit. All NX is doing is saying thier .042 jet is a 50 shot, while NOS says a .034 jet is 50hp.
NX is just telling you to run a bigger jet, it's not like thier kits are better and magicly make more power with the same parts. If you want to make "NX power ratings" with an NOS kit, just use the NX chart's jet sizes.
Old Dec 4, 2005 | 07:26 AM
  #32
hawjdude's Avatar
So I'm thinking about going this route, and was wandering if running reflash/s/afc together to tune the nitrous would be okay right. Thinking about just running a 50shot with 20lbs.
Old Dec 4, 2005 | 04:35 PM
  #33
bacalhau16's Avatar
im asuming that u would have to run ur reflash for everyday driving then with ur s-afc add some fuel when using nitrous. but like everyone is already saying, if u use a wet kit u dont need any tuning.
Old Dec 4, 2005 | 07:13 PM
  #34
rACerS's Avatar
Like i said, you do not need any tuning for a 50 or even a 75 shot WET kit. Just buy a fuel pump and spray it. And as always i recommend a Nitrous Express kit. The horsepower is rated at the wheels unlike the NOS kit which rates it at the crank.
How much hp a certain brand makes just depends on how much nitrous the jet flows.
Old Dec 5, 2005 | 07:03 PM
  #35
lemansz's Avatar
spray it...
Old Dec 6, 2005 | 10:09 PM
  #36
BURNALL_4's Avatar
Originally Posted by s10v8
so on a direct port setup, it can handle a 150 shot?
no 75 is probally safer 100 MAX
Old Dec 6, 2005 | 11:15 PM
  #37
mooreboost's Avatar
You all need to quit bench racing.
Get the car on a dyno, and tune it properly up to where you feel comfortable.
Like DSMotorsport has said, he has made 500 on a stock block, so that is feasible if you so desire.
95lsvtec
19
Feb 9, 2016 12:20 PM
06redrocket
E85 / Ethanol
Oct 17, 2009 11:37 AM
Fawkz
15
Feb 8, 2009 05:09 PM
njvlllrs
Dec 4, 2008 01:48 PM
Swift Drift 14
Lancer Aftermarket Forced Induction Tech
21
Nov 13, 2005 10:10 PM
