RS drivetrain will it fit a GSR?
Old Dec 3, 2005 | 07:15 PM
WillEatUrSTi's Avatar
Would a RS transmissioin and LSD fit a GSR? And will the 2005 drivetrains fit the earlier GSR's? Is it the RS and all 2005's that have the shorter gear ratios for 2005?
Old Dec 5, 2005 | 06:57 AM
4G63>OOOO's Avatar
Not sure what your end goal is.
If you want a front LSD, just buy a Quaife front diff from RRE, it has a lifetime warranty, which is rare in the aftermarket.
AFAIK, the RS and GSR gearboxes are the same, right down to the final drive and stamping on the case.
You can install a 6 speed on a 5 speed and vice versa, but you will need that model's shifter, cables and center console along with the trans mount on the pas side.
DCSilvrEvo's Avatar
Sure well dude!
Old Dec 5, 2005 | 07:39 AM
4G63>OOOO's Avatar
Originally Posted by DCSilvrEvo
Sure well dude!
I'm sorry, was that English?
Old Dec 5, 2005 | 07:50 AM
SuperHatch's Avatar
All 05 TC's are the same. Both 05 RS and GSR trannies are the same, the MR is a 6 speed (duh). 03-05 5-speed trannies are more or less the same, but minor revisions to the syncros and other various parts have happened over time. I don't believe the US RS has different gear ratios than the GSR. The 06 5 speeds have a slightly taller first than the earlier 5-speeds however.
Transmissions from 03-05 are all interchangeable 5 or 6 speed doesn't matter. To put a 6 speed in a 5 speed car the shifter assembly is also required. I believe the 06 trannies will also swap, I see no reason why they wouldn't.
Transfer cases are all physically interchangeable. If you have an 03-04 GSR and want LSD, get an 04 RS TC, a quaife, or a ralliart LSD. If you have an 05 or 06, you have an LSD already. You can put an 05 TC in an 03-04 car, it will physically bolt up, but it won't work, the electronics and hydraulics are not in place to support the ACD. You can put a 03-04 TC in an 05 to eliminate the ACD, I don't know why you'd want to do this, and I don't know what this will do to the electronics of the 05 car.
Hope this helps!
- Steve
Old Dec 5, 2005 | 10:10 AM
Wow thanks that was very helpful and was what I was looking for. I could have sworn though I remember reading that Mitsubishi for the 05 models shortened the gear ratios on the 5- speeds.
Old Dec 5, 2005 | 11:08 AM
SuperHatch's Avatar
Glad I could help!
evo8black
For Sale - Cars For Sale
Aug 6, 2013 10:21 PM
holmes14
Oct 18, 2010 08:52 AM
evovic
Jul 22, 2007 05:16 AM
caswanso
15
Feb 1, 2007 08:04 AM
JR4JC
Dec 13, 2004 12:16 PM
