need help evo 8 motor swap into 2g eclipse
Old Mar 24, 2003 | 10:08 AM
Z1 Performance's Avatar
The Evo 4 and up motos will not aork as they are 180 degrees from the Evo1-3 and US spec 4G63 Turbo motors.
As far as the swap, you are FAR better off selling your car and buying a GST or GSX of the same year and building it up...just watch out for crank walk
Adam
Old Mar 24, 2003 | 11:17 AM
Lan Evo's Avatar
I guess it's not him, it's his customer who's looking for that swap. Anyhow, that's what I'd suggest, too
Old Mar 24, 2003 | 11:44 AM
MalibuJack's Avatar
Your not really going to have an easy time of this.. You might want to consider a turbo upgrade for your 420a... bigger gains and alot cheaper than the endeavor you are considering. Also an AWD car has a different driveline altogether, which means quite a few other components would need modification or swapping, plus the chassis/floorpan mods required to accomodate it. If you want an AWD car, your best bet is to get a 1st Gen Eclipse AWD and modify it from there with boltons. Cost will be similar.
http://www.hahnracecraft.com/auto/eclipse/eclipse.htm anyway, if you want to improve performance without cutting up your car, this company has one of the best and most complete kits available.
Old Mar 24, 2003 | 11:47 AM
MalibuJack's Avatar
Now that I think of it.. If this was a bolton swap, EVO8 theft would run rampant and these drivelines would end up in these clapped out eclipses, talons, lasers... reminds me of back in the late 80's when someone discovered how to swap the mazda 12a/13b motor/tranny into the (rear drive) Toyota corollas, datsun b210's etc..
Old Feb 21, 2012 | 02:44 PM
Alex Conti's Avatar
i hear that the evo 8 motors will fit in the rs and gs models only. u just need aftermarket motor mounts for the torque and a different bell housing and i a gsx ecu if im correct. its been done. do some research. its out there.
Old Feb 21, 2012 | 02:54 PM
okevolutionVIII's Avatar
I would just drop a 1G 4G63 in it. And this thread is 9 years old.
purpleeclipse
Oct 8, 2014 04:20 PM
BoostNY
40
Apr 20, 2014 07:17 AM
need_an_evo
Jul 26, 2013 02:47 PM
williamgasdick
Northeast Region
Jul 15, 2011 02:26 PM
BananaStyle03
May 26, 2010 02:54 PM
