Turbo timer
Old Mar 21, 2003 | 01:45 AM
hotsync's Avatar
Turbo timer
Hi, just joined as member. I will be buying the Airtrek turbo-r. Just wanted to check with the master mechanic here, whether a turbo timer is required to ensure reliability for the EVO II GTA engine.
Old Mar 21, 2003 | 05:46 AM
JeffGST's Avatar
The engine itself will be reliable without a turbo timer IF you are willing to idle the motor at least a minute after driving. All you are doing is allowing the oil to flow through the turbo and cool off the bearings. A quick shut off will cause the oil to "coke" or basically cook on the bearings.
Ever stir fry and check the sides of the pan after your done??
That's what your turbo bearing will look like if you don't let the car idle for a while. Start the engine up the next time and you'll be grinding all that cooked oil around.
If you are will to wait, you can save yourself some money and not buy the timer. But if you are impatient, you will end up spending the money on a turbo rebuild.
Old Mar 23, 2003 | 07:58 PM
hotsync's Avatar
Jeff,
Thks for your advice. Is there a general rule pertaining to the timing before shutting down the engine?
I just read that, if it a short journey idling is recommended 3 mins and 5 mins for high rev long journey.
Cheers.
Old Mar 26, 2003 | 10:41 AM
DSM Power's Avatar
3 minutes of idling is plenty... You can also drive the car lightly (in other words not boosting) in the last few blocks before you park it... that will have about the same effect as idling.
Old Mar 27, 2003 | 02:25 AM
hotsync's Avatar
Thanks for your feedbacks.
I have decided to install the turbo timer. It is not too expensive, at least I don't have to worry about the waiting period etc... and probably set the timer to 2mins for the cool down period.
Freddy302
Oct 11, 2016 05:55 PM
Austin Kraft
Aug 7, 2012 07:32 PM
gudmundur
11
Jul 19, 2008 01:21 PM
veilside prius
10
Jan 6, 2008 12:19 PM
TheOnlyDC5
Jan 29, 2006 11:36 AM
