Winning from a roll.......20g vs GT35R
Old Dec 5, 2005 | 12:21 PM
IE Evo's Avatar
Originally Posted by Jasil
brake boost...not boost brake...Hold the brake and pressing the gas at the same time to create boost and then letting off the brake when roll racing.
My bad! U are right "boost brake". Try it you'll like it.
Old Dec 5, 2005 | 12:26 PM
ThunderOZ's Avatar
so hold the brake and gas down enough so u keep ur speed constant right....comparable to holding the brake down and gas at the same tyme in an auto for a lauch....i think
Old Dec 5, 2005 | 12:28 PM
Ev0ikon's Avatar
Break Boosting =wear your pads and rotor faster :P
But yeah it's how we get those bigger displacement cars .
Old Dec 5, 2005 | 12:30 PM
ThunderOZ's Avatar
gotcha...good to knw
Old Dec 5, 2005 | 12:42 PM
David Buschur's Avatar
Alright, went back to the dyno computer again.
Pulled up the 20G-8 dyno run that we did no race gas, 376 whp pull. I also figured out the MPH the car is running at 3,000 rpm to 7,000 rpm.
Here is more interesting stuff.
3,000 rpm = 32 mph
7,000 rpm = 75 mph
This is right where you'd be rolling through town and honestly for me to run through town at 35 mph I would personally be in 4th gear, that's how I drive. So, if I was going to play I would only drop down to 3rd anyway.
The 20G-8 on race gas made 376 whp and ran 32-75 mph in 3.24 seconds.
The 20G-9 on pump gas made 331 whp and ran 32-75 mph in 3.77 seconds.
The GT35R on pump/alky made 365 whp and ran 32-75 mph in 5.91 seconds.
Here is the kicker. A Stroker, GT40R that has run 10.1 at 144 mph ran from 32-75 mph in 4.53 seconds! This is with a WHOLE LOTA boost. The lag is just killer. Car made 580 whp on our dyno.
The spool up is killer and as you can see very important for the street.
David Buschur
www.buschurracing.com
Old Dec 5, 2005 | 12:49 PM
Blue Evo 8's Avatar
3,000 rpm = 32 mph
7,000 rpm = 75 mph
David Buschur
Dave can you do these runs in 4th gear? Like from 75-116 MPH or so?
Old Dec 5, 2005 | 12:50 PM
95GSXtoEVO8's Avatar
This is all extremely interesting. I have to ask, do you have any times for a stock 16G turbo with all the bolt-ons?
Old Dec 5, 2005 | 12:53 PM
I could do the pulls in 4th but I don't and won't. It takes way to long and I don't like the speeds the car has to hit to tune it. I prefer to tune in 3rd gear whether it's on the street or on the dyno. The gear loads the car enough to tune it properly and the pulls are over in much less time. Also, tuning in 3rd generally means that in the higher gears the AFR's, if anything will be a little richer.
Sorry, I'm just chicken I guess.
David Buschur
Old Dec 5, 2005 | 12:56 PM
Blue Evo 8's Avatar
David Buschur
Ohh okay, no biggie, I figure the numbers should be proportionally similar
Old Dec 5, 2005 | 01:50 PM
Juiced's Avatar
David Buschur
No need for apologies, i'm just use to the LS1 Scene where everything is done in 4th (1:1) i knew hondas and stuff dynoed in 3rd because of the lack of tq to turn the drums i just didn't know if at some point you went up a gear.
I increadibly impressed with your work.
i more thing why is the 20g-8 making more hp than the 9 in your comparison, are you still tunning it?
lemansz's Avatar
average power beats peak.. mooost timess....
also dont forget a wiley driver beats most of time...
even with inferior equipment.
as far as tuning.
its wise to start in 3rd, where the car has less time and less load to "cook".
most tuners will move onto 4th gear to fine tune the ... tune. myself included.
alot of higher hp cars wont respond to the load the car sees from the rollers in 3rd. With a high torque car even 4th, wont get the car loaded like the street will.
more load usually means more boost and higher fuel consumption.
most cars will also show more power in 4th than in third
more in third than in second
more in second than in 1st
etc
this is more drastic with turbo cars, but not limited to.
For example my old NA z06, showed more power in everynumerically higher gear.. until 5th where the dyno hit max rpm, and shut down.
Old Dec 5, 2005 | 01:51 PM
fuzzychi's Avatar
How much is the 20G-9? And I think the numbers were higher for the 20G-8 in the comparison because it was on race gas where as the 20G-9 in the comparison was on pump gas.
Old Dec 5, 2005 | 02:00 PM
kmcconn9's Avatar
I would be very interested to see the 20g-9 on alky/race gas...
Old Dec 5, 2005 | 02:03 PM
fuzzychi's Avatar
That's what I was thinking for my car in the future
EvoLee's Avatar
+1 for this info because this might be the deciding factor on upgrading my turbo next. I'm running the stock turbo with Buschur's Stage 3 (264 cams) upgrades. How about some numbers for this one Dave....
Also, would this require another flash, too?
EvoLee
