Yet another boost/bov/timing question...
Old Dec 7, 2005 | 09:32 PM
naucrx's Avatar
THis is the second time you've said this. Are you trying to say "tee'd" or "T'd," or do you really mean to say "tied"? NOthing is tied, but maybe it's just your choice of words? There should be a separate vaccuum hose for both the turbo nipple and wastegate nipple.
It's just a choice of words. His MBC is "attached" via two hoses - one to the turbo nipple and one to the wastegate. Hey it's late! lol
Old Dec 7, 2005 | 09:37 PM
95GSXtoEVO8's Avatar
what kind of knot did you use? slip knots are no good...
yes it's late.
Old Dec 7, 2005 | 09:55 PM
C6C6CH3vo's Avatar
My forge rs bov does that upon building psi from vacuum to peak, at lower rpms from 2nd gear up and much of throttle settings.
I just adjusted the spring all the way loose and it's gone.
Old Dec 7, 2005 | 10:00 PM
SP00LIN's Avatar
I've never messed with the wastegate. Do you think that could affect the surge?
Old Dec 7, 2005 | 10:04 PM
Killboy's Avatar
Yeah the Forge RS is almost ideal since it's adjustable, but the spring seems a little strong. I have to keep it all the way loose and it still flutters in 4th/5th between 3-4k rpm when I lift off the throttle just as it's starting to make strong boost.
I'm recirculating and was using the single piston, but I just cleaned/lubed it and I'm going to give the dual piston a try. I have a discussion started with Forge over here:
http://www.uk-mkivs.net/forums/419402/ShowPost.aspx
Old Dec 7, 2005 | 10:11 PM
precisi0n's Avatar
check your pm spoolin
Old Dec 7, 2005 | 10:14 PM
precisi0n's Avatar
I dont want to hijack this thread but I am having some issues with myBOV as well. i have an hks SSQV... I cannot run any more than 21psi while recirc and I get tons of flutter... As soon as I VTA I can hold 28psi just fine and almost no flutter... any ideas??? I checked everything for leaks on each install and everything seems fine
