Manual Boost Controller Hose Length
Old Dec 9, 2005 | 06:18 AM
whitet777's Avatar
I recently purchased a Forge UNOS MBC. Ideally, I'd like to put the controller in the car, not under the hood, for adjustability purposes. I haven't found a thread that said it couldn't be done that way by running the hoses through the firewall.
My main concern is whether or not the MBC with long hoses will cause a slow wastegate response causing spikes and such. I imagine the shorter the hoses, the better.
Can anyone chime in? And, I've seen a few posts on what hose size to buy, but I'd just like a fresh opinion on that too.
Tim
Old Dec 9, 2005 | 06:46 AM
C6C6CH3vo's Avatar
Tim
"the shorter the hoses, the better" is 100% correct when dealing with WG control pressure. Keep the hoses as short as possible. You will get ugly spikes with hoses that long.
Old Dec 9, 2005 | 08:52 AM
RogueSTi's Avatar
Agreed. Get a MBC with a remote operator if you want to mount it inside.
Old Dec 9, 2005 | 09:10 AM
whitet777's Avatar
Thanks.
Any opinions on hose diameter and/or type?
Old Dec 9, 2005 | 02:57 PM
C6C6CH3vo's Avatar
I just reused the same hosing that was fitted on the factory tee fitting/solinoid/wastegate act/intake contraption - there was more than enough.
Dont forget to keep the solinoid connected to the harness - you can cap the solinoid's nipples or take a 2" section of hose and plug ea end to it.
My MBC is mounted so there's no more than 8" of hose to both the WG act and housing. I encounter no spiking.
It's a little tricky to adjust but I made a tool with a gripping end and it's easy.
drb
53
Oct 25, 2016 07:50 AM
mike594x
Dec 11, 2015 06:29 AM
smartidiot2122
Lancer Engine Tech
Apr 21, 2009 05:20 PM
ku7484
Jul 12, 2005 03:35 AM
anjapower
34
May 26, 2005 11:05 PM
