Apex'i AVC-R or HKS EVC boost controller?
Old Jul 10, 2005 | 08:38 PM
ku7484's Avatar
My MBC isn't holding the boost, so im gonna buy a electronic boost controller and hope for the best. Yes my MBC is installed correctly and yes i've checked my hoses and for leaks etc. Its about time i sack up and buy a electronic boost controller, but i can't seem to choose between the Apex'i AVC-R or the HKS EVC boost controller. I've heard excellent things about both of them, but i would like everyone's personal opinion.
Old Jul 10, 2005 | 09:27 PM
fre's Avatar
fre
I own an AVC-R and I think it is a great boost controller. I just rewired it to monitor injector duty cycle instead of rpm which is important info to have It has two separate maps for boost and you just adjust your duty to match the target boost you enter. Really easy to use and easy to adjust boost. I haven't seen the HKS so I don't know how good that one is.
Old Jul 10, 2005 | 11:39 PM
ku7484's Avatar
thanks for the info! so how well does the avc-r hold boost? are you spiking high and dropping boost at all? Or is it holding strong all the way to redline? How much boost are you pushing, and do you have any form of ECU or FLash to help hold the boost?
Old Jul 11, 2005 | 02:50 AM
4G63 Power's Avatar
i have friends with both. both work well without any issues.
the avcr has more features but requires splicing into the ecu harness. also the evc is a litle more straight forward setting up. so it mostly depends if you want the added features and bright blue display.
Old Jul 11, 2005 | 12:49 PM
jmartinez1170's Avatar
apexi all day its a lil more easy to play with then changing 6 screens just to set the boost on the hks
Old Jul 11, 2005 | 01:45 PM
EVIL MR's Avatar
apexi is the way to go
Old Jul 11, 2005 | 02:25 PM
ku7484's Avatar
thanks guys!
evil mr - are u currently using the apexi? and how well does it hold boost?
Old Jul 11, 2005 | 05:45 PM
fre's Avatar
fre
Holding boost till redline is more of a turbo issue not the controller. I hold 28psi till 8k rpms right now just fine. You can control how fast boost builds/spiking in the start duty function. It breaks down your gears from 1-5 and you pick how much to "advance" or "retard" the duty cycle in each gear. The more you advance the quicker you build boost, but the more spike you have.
Old Jul 11, 2005 | 07:16 PM
Karash's Avatar
I have the AVC-R and it works just fine...in fact I love it.
My friend has an EVC in his MR and he seems to love his EBC just as well..
to be honest, you cant go wrong with either.
Old Jul 11, 2005 | 08:20 PM
badlooser's Avatar
I have had the HKS evc 5 and am now using a AVC-R and can say I like the simplicty of the HKS display and the turn the knob boost control but the AVC-R does so mutch more. Injector duty cycle display is cool to moniter and the gear learing feature came in handy when tuning on the dyno. I say it is a toss up both are good pieces but I will not be riping the AVC-R out of my car as I did with the HKS.
Old Jul 11, 2005 | 08:41 PM
ultra721's Avatar
Anyone interested in buying a brand new, still in the box, avc-r and fields harness? I bought it 2 months ago and I don't need it anymore. PM me if your interested.
Old Jul 12, 2005 | 03:35 AM
krayzeviet's Avatar
i have the avcr.... i wanted to match my safc2
axxevo8
Nov 22, 2015 08:20 AM
Knightracer
Jul 18, 2010 08:43 PM
Johnny6er
10
Dec 29, 2007 09:04 PM
CrackerJackToy
Aug 11, 2007 06:54 PM
Kayaalp
Northeast Region
Jan 26, 2006 12:42 AM
