Jun Flywheel
Old Dec 11, 2005 | 04:38 PM
Yaroslav's Avatar
Question Jun Flywheel
Can I Install Jun Flywheel With Twin Disk Clutch?
For Example - With Carbon Tilton?
It Weights Only 3.8kg And I Hope To Rev It Much Faster And Improve Acceleration
Thanks
Old Dec 11, 2005 | 05:09 PM
Mike@Forge's Avatar
Most (virtually all) multi-plate clutch assemblies come with their own flywheel.
I don't know much about the JUN flywheel, but I imagine if it's sold by itself, it needs to be paired with a single plate clutch. (ie: sold separately)
Old Dec 11, 2005 | 05:14 PM
ACTman's Avatar
No. The Tilton and basically all multiplate clutches take flywheels exclusive to that clutch. The Tilton is very light (especially the carbon/carbon) so there would be no advantage to using a Jun flywheel. Keep in mind that if you go too light, there is less material to soak up heat which of course affects clutch durability. Note: Since the carbon/carbon doesn't rely on steel as the friction surface, this is less of a problem.
