bov on ic pipe or intake
Old Dec 13, 2005 | 11:20 AM
jesterEVO's Avatar
I have the buschur maf intake, logic performance ic kit. I currently have my Aps bov on IC pipe and it seems to flutter on turbo spool to when i let off throttle around 6k rpms. But on WOT it makes the sound it should. Think i should keep the BOV where i have it or relocated to intake pipe or adjust bolt at top of the BOV? Never touched it just put it in like as....opinions?
Old Dec 13, 2005 | 01:00 PM
Juiced's Avatar
If you relocate it to the intake pipe it will become useless.
Just adjust the BOV it doesn't flutter under partial throttle.
Old Dec 13, 2005 | 01:03 PM
Spaceball 1's Avatar
it wont become useless, you could try it and it will make it louder but it sounds more like it needs adjusted as juiced stated
Old Dec 13, 2005 | 01:07 PM
jesterEVO's Avatar
ok i will turn the top a small bit see what it does
Old Dec 13, 2005 | 01:10 PM
2hot2handle's Avatar
can you take a couple more pictures, you may have it backwards.
Old Dec 13, 2005 | 01:19 PM
Juiced's Avatar
Are you serious?
Can you please explain the point in having a BOV in the intake pipe?
You do know the intake pipe is unpressurized.
The Upper Intercooler pipe is pressurized and is where the BOV should be.
Old Dec 13, 2005 | 01:22 PM
the stock configuration has the BOV "mounted" to the Intake. In his picture the BOV is mounted to the UICP. It can be moved to different spots and still have the pressure be on the correct side of the valve. Your are correct in saying that the BOV should be mounted to the Pressurized UICP less pessurized amount of air even thought very same difference but when you are recirculated like him you can move it back to the stock location and it may change the vaccum/boost difference and cause the valve to work better/worse.
Old Dec 13, 2005 | 01:30 PM
Juiced's Avatar
If i were u would quit trying to explain something you obviously know nothing about.
The setup is corect if it wasn't he wouldn't have the fluttering problems.
You have a hose that goes form your UICP to the BOV, form there it discharges into the Intake (MAF) pipe.
there's only one way to set up a BOV and have it actually vent.
Old Dec 13, 2005 | 01:33 PM
sorry but you are very wrong. answer this where is the BOV located from the factory where an engineer like me is getting paid very good money to design something?
Old Dec 13, 2005 | 01:44 PM
ibanez_926's Avatar
There is your answer
on topic just adjust it until the flutter goes away
Old Dec 13, 2005 | 01:45 PM
thank you jucied couldnt return
Old Dec 13, 2005 | 01:50 PM
jesterEVO's Avatar
cool i jsut went out and loosened the screw at the top of the bov a small bit to see what happens..havent drive yet...
Old Dec 13, 2005 | 01:51 PM
jesterEVO's Avatar
well buschur has his bov on his upper ic ..so i agree its a better spot...i saw a turbo kit on a supra with the bov located on the ic pipe.
Old Dec 13, 2005 | 02:05 PM
rsboy's Avatar
If you installed as APS instructed it should be working fine. The problem with mine is that in the cold, it does flutter ALOT more than it did during the warmer days. You can loosen the nut at the top and it should help some. I did it and it doesn't flutter that badly.
Here's how mine is setup with the Injen pipe kit:
Believe me... with the Forge bov I had, the fluttering was constant no matter what spring I had on it. The APS is much smoother and holds boost as well.
Old Dec 13, 2005 | 02:12 PM
Fourdoor's Avatar
From the factory it is mounted on a hose connected to the upper IC pipe, and has another hose (the discharge hose) leading to the intake pipe between the mass airflow sensor and the turbocharger.
A BOV mounted on the intake pipe would do absolutly nothing. You seem to not no the pursose of the BOV or you would not have these missconceptions.
Where did you study engineering?
Keith
PS: As much as I would love to, I will not be drawn into a flame war over this.
