GSC Cam Sec Release!!!!!!!!
Old Dec 21, 2005 | 08:30 PM
GregGSC's Avatar
Originally Posted by anjapower
So you're saying GSC cams defy physics? Less duration and less lift = less power.
The difference between the V1 and V2 are simple. its the polishing of the lobes. there wont be any performance differences at all. By polishing the lobes rather than coating it will allow for faster break in's. just so you don't feel bad our own evo has 264/264 mixmatched cams. and made 341whp at 25psi.
When i get back from Christmas break i will messure the HKS cams and compare the numbers of ours to the hks setups.
***Actuators are instock but all the employees will be out of stock till tuesday***
Old Dec 21, 2005 | 10:24 PM
NDgsx's Avatar
Depends on the ramp profile also. If you honestly think all there is to a cam is duration and lift you need look into this more. I can give you two cams with the same numbers that perform drastically different depending on the ramp profile.
Old Dec 22, 2005 | 04:44 AM
Ultimate CC's Avatar
PMed you
Old Dec 22, 2005 | 05:09 AM
anjapower's Avatar
Of course, but considering that ramp profile never seems to be a measured or publicized specification...how is one supposed to determine that?
Further, is a more favorable ramp profile enough to overcome lesser lift and duration?
Old Dec 22, 2005 | 09:20 PM
NDgsx's Avatar
Honestly the only way to determine it is real world testing, which I realize is totally cost prohibitive for an indivdual.
I'm not sure, I've never tried a cam that had less duration and lift, but I have run cams on DSMs that have near identical specs, but radically different ramps. The FP3s pick up nearly 40hp on the top end on a stroker engine, but have no more duration or lift than the FP2s:
FP3
As you can see the FP3 gets near full lift much quicker and holds the valve there longer.
Old Dec 22, 2005 | 10:23 PM
YellwTyper's Avatar
But why overlap on a turbo car?
Old Dec 22, 2005 | 10:32 PM
timzcat's Avatar
Originally Posted by GregGSC
Broadest power increase of any Evo cam on the market...
Let's all back up here, how can you make this claim? Have you tested every cam on the market on the same car in the same conditions and you can prove this?
Old Dec 22, 2005 | 10:37 PM
There have been a couple post reguarding this, one that strikes my memory was done down in PR where several evos all with similar mods got dynoed and the ones with gsc cams made about 5 more whp across the board comparably. It would be nice to have some raw data though with the same car being dynoed.
Old Dec 25, 2005 | 05:33 PM
trinydex's Avatar
because overlap gives you a cleaner cylinder.
Old Dec 25, 2005 | 05:45 PM
sleet's Avatar
Too bad they don't make 280s tho, I already bought my HKS exhaust 280.
Old Jan 10, 2006 | 12:47 AM
lqdchkn's Avatar
BUMP For after Christmas comparison.
Thinking of getting GSC's instead of JUN's or HKS' and want more info.
Old Jan 10, 2006 | 12:54 AM
Derek888's Avatar
GSC,
Where are you cams made in?
Old Feb 7, 2006 | 07:49 PM
anjapower's Avatar
bump # 2 for after christmas comparison.
Old Feb 10, 2006 | 08:06 AM
Zeus's Avatar
Oh yes, what ever happened to those GSC specs? I wanted to be able to compare the popular options out there!
Old Feb 10, 2006 | 08:13 AM
anjapower's Avatar
Good luck, it's like pulling teeth getting those specs
Jimevo9PI
For Sale - Cars For Sale
41
Jan 27, 2014 05:25 AM
liteSPEC
217
Feb 12, 2013 02:37 PM
roo@bpauto
14
Feb 14, 2006 05:23 PM
Chris@nolimitmotors
Feb 6, 2006 12:47 PM
avengerhed
Sep 10, 2005 10:33 AM
