evo spun out... now CEL
Old Dec 26, 2005 | 07:58 PM
smokedmustang's Avatar
Did it work? updates when you get them.
Old Dec 27, 2005 | 07:34 AM
USAF_STi's Avatar
Seen another thread about this. the guy got it pulled and it said that it was the cam positioning sensor. nothing was damaged and the car ran fine afterwards. i will try to search for the thread.
Old Dec 27, 2005 | 07:37 AM
did the light go away with the battery re-set? just wondering. thanks for looking.
Old Dec 27, 2005 | 07:42 AM
highvoltz's Avatar
If you reset the ecu, the cell will come back on if there is still a problem... So give a shot by disconnecting and cross the fingers it doesnt come back on
Old Dec 27, 2005 | 07:43 AM
Agreed!
Old Dec 27, 2005 | 05:58 PM
RSGuy's Avatar
The same kind of thing has happened to me before. Im almost willing to bet $100 that it is a misfire code. No biggy. Go get it cleared at an Autozone or something.
~fred
Old Dec 28, 2005 | 08:22 AM
Whats up with this? he asked for help, we gave it, and NO update? if someone else has this problem, they will need to know:
1. What code it was
2. What remedied the problem.
WHATS UP!?
Old Dec 28, 2005 | 09:22 AM
dubbleugly01's Avatar
you most likely spun the motor backwards when you spun out. Either the crank sensor or cam sensor probably threw the code. If you disconnect the battery and clear the code, I'd bet it would be problem solved like everyone is recommending.
