Troubleshooting: Clunking Sound in Rear
Old Jan 3, 2006 | 05:52 PM
dsmfan95's Avatar
Ok before I get flamed, I did search through about 4 pages of thread and found one talking about the same exact thing my car is doing, but no one gave an answer.
Whenever I let the clutch out quickly after a shift, I get the clunking sound coming from what seems to be the rear. I've checked the trunk to make sure nothing was sliding around and everything seemed secured. It does it from 1-2 and from 2-3, but it's very faint from 3-4 or higher.
Any suggestions would be appreciated
Old Jan 3, 2006 | 05:56 PM
WHTEVO's Avatar
It sounds like this is from your driveshaft. It has a slight amount of play when spinning so when you shift and engage the clutch quickly it just sends a little bit of shock to it.
Old Jan 3, 2006 | 06:39 PM
dsmfan95's Avatar
So is this a normal thing?
Old Jan 3, 2006 | 06:41 PM
Kerr's Avatar
Fomer Vendor
I get a noise when braking somtimes. It sounds like the calipers clamping down to me.
Old Jan 4, 2006 | 07:04 AM
Jasil's Avatar
I've been in 2 05's and 1 06' and normal or not any quick shifting resulted in a clunk. My 05' can clunk in every gear 1st-4th if I shift like I do at the track.
Old Jan 4, 2006 | 07:18 AM
evoviiiny's Avatar
My 03 clunks when going in reverse when I push in the clutch. idk thats just the joy of owning an evo.
Old Jan 4, 2006 | 07:25 AM
Silver05Bullet's Avatar
i used to get the clunk in the rear but no more i think i adjusted my driving, i used to get a bad bang when shifting hard at like 7300rpms
Old Jan 4, 2006 | 08:48 AM
EvoVIII_SFL's Avatar
possibly try not shifting so damn hard.
i had this issue in my 03 when i thought i was driving a honda, then i realized i was in an awd evo.
my 05 is fine too (because i drive it properly)
Old Jan 4, 2006 | 10:43 AM
EvilBlueEvo8's Avatar
i get a clunking sound every once in a while. almost like a loose socket or something. i read on here somewhere that someone had a similar noise and then put in a torque dampner and the noise went away. maybe you could try that?
Old Jan 4, 2006 | 10:52 AM
deffro's Avatar
It's normal, all evo's will do it, but if you don't drop the clutch so fast the sound won't happen
Old Jan 4, 2006 | 10:55 AM
JaReDbOy's Avatar
mine's done it since day 1. i drive her hard, but its always done it and the car works fine.. so i wouldnt worry too much.
Old Jan 4, 2006 | 11:02 AM
it also happens to me more often when the temp is cold out.
Old Jan 4, 2006 | 12:56 PM
JaReDbOy's Avatar
Yea I would agree with the tempature thing too.
While we're on the topic, does anyone else's clutch feel "sticky" when its cold out?
My clutch doesnt slip, but it feels like the pedal is "gummy" and kinda holds back and then will pop up at the top- mostly noticable when its cold out.
Any ideas?
Old Jan 4, 2006 | 01:37 PM
dsmfan95's Avatar
I'm not shifting hard
My car hasn't even hit the break in period yet so I haven't ran it hard at all. I just shifted while getting on the interstate and I guess I let the clutch out quicker than normal and *CLUNK*. By no means did I drop the clutch out while shifting, I just slipped it out quicker than normal driving.
Old Jan 4, 2006 | 04:20 PM
Jasil's Avatar
If by hard you mean fast there is not much you can do. If I powershift second it's "Wham" the only time it doesn't do it is if I shift slow that's it. Any powershift or fast lift shift and it's a big "Clunk" or "Wham" whatever you want to call it.
