stiff/soft spring
Old Jan 9, 2006 | 01:42 PM
iceman01's Avatar
stiff/soft spring
hey im about to buy the forge unos mbc w/ soft spring...i have no mods and this would be my first...i drive an '03 evo--my question is would the soft spring for the mbc be alright since im not gonna be holding higher boost as i would if i buy the stiffer spring?? thanks
Old Jan 9, 2006 | 02:41 PM
nigletsyz's Avatar
either, doesn't matter. soft spring will start out at 11psi, maxes out at 21psi. Stiff spring starts around 17psi, maxes around 35. Please correct me if I'm wrong.
Old Jan 9, 2006 | 03:46 PM
Warrtalon's Avatar
Just do the soft spring and max it out. That will be perfect for you with your setup. Switch to the stiff spring if and when you go with alky, race gas, or a larger turbo.
Old Jan 9, 2006 | 03:52 PM
iceman01's Avatar
hmmm ok thanks!
