HKS 9 Cams at Sema...
Originally Posted by 3000ways
When the Cams become available for USDM model IXs and if they make larger gains on the IX compared to VIIIs (I'm talking 10WHP to 20WHP) then that's it, I'm done. I'm scratching plans of purchasing a used 03-04 in June or July, and saving up another 6 or 7 months for a IX.
Hmm... Does this mean that MIVEC control will be integrated into HKS' V-Pro soon...? Hmmmm.... Or do you run this MIVEC control box in conjunction with a piggy back / standalone? Confusing...
Originally Posted by 1 low mx6
I would wait, i work at a mits dealership and drive an 03 everyday to work with boltons and the stock IX's are just as fast. a IX with bolt ons is sick for a street car!!
I'm curious to see these cams, can anyone scan this article?
Originally Posted by kcevo
As a matter of I was looking at the Vpro software the other day and they have a basmap set up for the 9 already.
Ahhh... you ARE a HKS Pro dealer... That's funny... no other Pro dealer on the forums have chimed in with that information yet... hmmm...
Well have any of them dealt with the new 3.24 box or are they still dealing with the 3.23(better known as 3.2). The 3.24 box just came out which has the evo 9 wizard settings.
Have seen it in the latest Japanese Option magazine where HKS Kansai did a dyno test on 3 different settings on these specially made cams advancing and retarding the inlet cams on the Evo 9. It really is like having adjustable cam gears on the fly. Values were like in the range of between 100 to 130 degrees on the Variable Cam Timing controller. Good stuff...
By the way, do you have a part # for the 3.24 version?
Does the 3.24 have a separate map for MIVEC built in as well?
You can setup a seperate sub map to control the cam timing, but they are not sure how it's going to completely work. SP is actually doing the first one in the States, and they are setting it up using a seperate sub map to control the timing. At this time they are suggesting to let the stock ecu control the MIVEC timing until they can figure out what exact parameters trigger it.
Incidentally, there's a thread about IX tuning with HKS products (co-project between EVasive and SP)... no info on a IX specific V Pro harness...
TurboTim06
10
Nov 18, 2011 07:37 PM
