Neisop dsmloggers chat
Old Jan 14, 2006 | 08:58 AM
dryad001's Avatar
Did everyone get the obd gauge along with the package? I treid the Plam n stein last night, I need more time to figure out how to cruise through the pages. But I really like the obd gauge program, very simple to use. There is only 4 main pages and is set-up windows based via drop down menu's.
Also I can't find a way to Hot Sync using a DB9 to USB converter I have to rely on my ancient laptop with a serial port
Ill post more as I get more familiar with both programs, or if anyone has different freeware out there, post up the links.
Old Jan 14, 2006 | 10:51 AM
djskyy's Avatar
Yeah, I tried playing with it, but it just says "intializing....", so I'm not sure if it's working or not.....
Old Jan 14, 2006 | 12:26 PM
Nesiop's Avatar
Thank you for creating this section. I will play around with it more myself once the weather is alright. Evo is pretty much away in the garage because I live in MA but occasional days I can play around.
Old Jan 14, 2006 | 10:26 PM
dryad001's Avatar
Same thing happens here. Ill play with it tomorrow, when I loaded it to the palm it seemed like it took about 5 minutes, but the other palm n stein took about 30 seconds. The file could be corrupt. I'll delete the current version and load up another from google search.
Edit: I just did a little research about the obd gauge program. I have the entire .pdf file for the obd gauge but it's too large to upload here so if you want me to e-mail it to you send me your address and I will get it out asap.
But to make it a little quicker follow these steps:
Under "Interface", select "Multiplex"
Tap the "setup" icon
Choose the "Baud" and "Address" setting as appropriate for your interface (typical baud is 19200 and address is 25)
Choose the "protocol" setting for the vechicle
If this doesn't help, not sure what it is then.
tephra
60
Apr 17, 2012 09:34 PM
DynoFlash
13
Feb 9, 2009 02:03 PM
CLaNZeR
Jan 11, 2009 07:32 AM
MalibuJack
Nov 9, 2006 08:10 AM
silex
Feb 26, 2006 12:18 AM
