Car wont start, what to do now???
Old Jan 14, 2006 | 02:15 PM
shiftdsm E's Avatar
pop starting your car... http://www.ehow.com/how_7414_push-start-car.html thats far better than i could explain it, can be done forward or reverse. go for it if you can.
Old Jan 14, 2006 | 02:17 PM
EVOLVEU's Avatar
its turning over and trying to start. Its shudders like it is, but doesnt.
Old Jan 14, 2006 | 02:18 PM
EVOLVEU's Avatar
so thats what its called, well, I tried this too. No luck
Old Jan 14, 2006 | 02:36 PM
EVOLVEU's Avatar
anyone else??? any idea is better than no ideas!
Old Jan 14, 2006 | 02:44 PM
EVOLVEU's Avatar
Originally Posted by jxn evo 8
Before this happened did you have trouble keeping the car running. I mean like when the car was at idle or at low RPMs did it every just dye? If you had these symptoms you may have a bent valve.
It did start to idle kinda rough. It died sometimes, even after the flash, which i thought was weird. When you say bent valves, do you mean the valvetrain?(springs/retainers)
Old Jan 14, 2006 | 02:48 PM
silverEVO8's Avatar
Originally Posted by EVOLVEU
it is cranking, but wont actually start.
Sounds like it might be the timing belt jumped some teeth..... That happened to me before. If a car has had cams or cam gears installed, it's possible that the tensioner can fail.......
SilverShadow03's Avatar
Ok, first my list of mods:
HKS 272s
Walbro 255
AEM Intake
Fidanza camgears
Koyo Radiator
Turbosmart BOV
Turbosmart MBC @21 psi
Autometer Boost Gauge
Dynoflash mail in flash
Just put in ngk spark plugs with .026 gap
Make sure one or both of the cam gears didn't losen up and throw your cam timimng off several degrees....might be a reason why....
Old Jan 14, 2006 | 02:51 PM
EVOLVEU's Avatar
Would that cause it to not start at all? Ill check that tomorrow morning. If there are ANY other ideas, please let me know!!!! Ill put it on my to do list for the morning!
Old Jan 14, 2006 | 02:52 PM
silverEVO8's Avatar
The cam gears probably can't move enough to cause this. OTOH, if the belt jumps more than one or 2 teeth, it could cause this...
Old Jan 14, 2006 | 02:54 PM
silverEVO8's Avatar
Dude, I've told you already.... The belt could have jumped some teeth due to tensioner failure. The tensioner can easily fail if the belt or cams/cam gears are changed. This will definitely cause the car to not start.. It might not be this, but it's a very strong likelyhood.....
Old Jan 14, 2006 | 02:55 PM
Gotcha....makes sense....I was also thinking since he was at WOT it could have loosened and jumped a couple of teeth.....just a suggestion....
Old Jan 14, 2006 | 02:56 PM
EVOLVEU's Avatar
ok, Ill check in the morning. Ill let everyone know how it goes!!! BTW, thanks for the advice!
Old Jan 14, 2006 | 03:00 PM
Thumbs up
good luck and let us know...i'm curious to see what it turns out to be.
Old Jan 14, 2006 | 03:50 PM
silverEVO8's Avatar
Actually, in my case it was not related to WOT or anything like that. The car was in the body shop to repair a crash (I was rear ended). Anyway, they were just starting the car to move it around in the shop when it suddenly would not start.... The problem was diagnosed and corrected by Andrew at Dyno4mance. I had the car taken there on a flat bed truck after the body shop finished the work. Apparently he noticed straight away that the belt had jumped teeth. Fortunately there was no valve train damage. I found out then that the tensioner is a one time use item. Seems like some shops reuse those tensioners when they do cam gears, etc. This causes the belt to eventually jump teeth. When Boost Solutions changed my cams and cam gears, they obviously reused the tensioner... Now, I'm not certain this is the problem with his car, but it definitely could be.....
Old Jan 14, 2006 | 05:43 PM
nlped's Avatar
Yes, be very wary of reusing the tensioner...major issues could shortly follow. I hope it turns out to be a simple issue for you.
