idle question
Old Mar 27, 2003 | 03:47 PM
yycools's Avatar
my evo idle around 1k-1.5(cold start)k I think thats normal. octane booster is not a good idea, better to run 93 off the pump or mix your own race gas, just do a search on this topic and a few will pop up.
Old Mar 27, 2003 | 03:48 PM
SilverEvoVIII's Avatar
hey yycools
where are you getting 93 for yoou evo? all i usually see around is 91
Old Mar 27, 2003 | 03:57 PM
yycools's Avatar
93 is everywhere in MA, Try the Gulf on VFW PWY
Old Mar 27, 2003 | 04:04 PM
thanks- i maybe imagining things ................it is scary how bad my momery is for an 18 yearold..........i cant imaginew what it will be liek when i am 60
Old Jun 12, 2003 | 12:54 PM
boostedwrx's Avatar
i only use 94 right out of the pump!
Old Jun 12, 2003 | 12:58 PM
iodine23's Avatar
evo8: Are you running the A/C? It could be the compressor kicking on. If you are, try punching the button when the rough idle starts and see if it goes away
Old Jun 12, 2003 | 12:59 PM
2Cool's Avatar
The AC cycling effects idle, so you may notice it stumble slightly when the compressor kicks on.
I dialed my idle down to 850 via the idle air bypass screw on the throttle body, thats about as low as it will go.
Old Jun 12, 2003 | 08:35 PM
Crufty Dusty's Avatar
Interesting. What is the idle speed for the USDM? On the JDM 7 and 8 it is 850 RPM. It's even stated on a sticker which is pasted on the underside of the hood.
Old Jun 12, 2003 | 08:39 PM
ratboy128's Avatar
do you know if the normal lancer has a screw to adjust idle like the evo does? cause mine is idling really low
Old Jun 28, 2003 | 11:37 PM
Thoe99's Avatar
My car is brand new and it has a little bumpy idle all the time. Not very noticeable, but if you are picky, you will feel it. Don't know if that's normal or not. And that's with or without the AC on.
Old Jun 29, 2003 | 12:51 AM
the evo wins's Avatar
Yeah after a while my idle bumps up for a bit and then drops back down..
Old Jun 29, 2003 | 01:05 AM
I4K20C's Avatar
Maybe i should've started a new thread for this, but didn't want to since this kinda goes with topic!
Compared to alota cars the Evo seems to idle a little higher, i herd that when cars idle high it's bad.. but why?
Old Jun 29, 2003 | 01:12 AM
ishi's Avatar
It's norm.... ALL EVO's run alittle rough time to time. Especially compared to other cars (except maybe rotarys) Nothing to be really concerned about Just give enough time to warm up before driving. On hot days let engine warm up before turning on the AC....
