IT'S OFFICIAL.... my engine blown up !! 29,000 miles
Originally Posted by levo2nr
so how much is to build the new motor?
oh and do u have any problem with the cold start with aem ems?
ahhhhhh .... I can't post that because I get wholesale on alot of stuff, But AMS sells shorblocks for about $2900 with is a decent retail price.
Originally Posted by jqturbo
It's an 03' and it blew with 29K miles, but how many miles did it have on it when you purchased it?
What mods did it already have??...sorry if you covered this already.
Was it hard to pull the motor?My core support is off right now so i have lots of room.Best just to pull tranny and all right? .found out my block has a crack
I would like to do a stroker.Well good luck on the build keep us posted
damn that sucks.............my order was front diff, tranny & engine. I 'm not doing a stroker because... you really don't need it.
Originally Posted by Torre from Va.
sigh............. I ran good for awhile until it got cold.
I had the AEM EMS and a whole bunch of associated mods done to my previous '03 EVO and it was a disaster. I eventually removed the EMS and a whole bunch of stuff to get it running half way right. Any time you get a stand alone or even a piggyback, it needs to be retuned when the temps change from winter to summer and viseversa. That's the reason the stock EVO computer can be reflashed or tuned for more power. The OEM settings are safe for practically all conditions except really low octane fuel.... I would not be surprised that even reflashes have an element of danger to them, particularly if they are done for maximum power during hot weather.... I can easily see how such a "tuned" ecu would allow lean running conditions = knock, in the cold winter days.
Originally Posted by silverEVO8
I hate to tell you this, but I believe your used EVO was not bad.... If the car ran well for a while and suddenly developed problems when it got cold, it means that most likely your AEM EMS tune was off or some part of your EMS or associated sensors failed to do the job. I have broken engines in the past in a manner very similar to what you describe. I was definitely a case of running too lean in the cold days of winter. The car ran great in ths summer, but when it gets cold, your air is much denser and you'll run very lean. This will cause knock, which will do the damage you see..... Unless the tuning is done spot on for all possible conditions, you will most likely blow your next engine as well.
Originally Posted by lucas569
wow this scares me from buying a used evo
