Boost Settings
Old Jan 20, 2006 | 05:23 PM
Ph3n1x's Avatar
Boost Settings
yeah yeah, I'm too tired to look.
Easy question:
Max boost on pump gas 93 octane?
I have Boost set to 1.6bar which is little over 23psi
should I turn it down a notch?
Old Jan 20, 2006 | 05:30 PM
4WS Tuning's Avatar
21/22 i believe is safe probably could do 23...but as far as my understanding is concerned its a bad idea...
Old Jan 20, 2006 | 05:34 PM
Nez136's Avatar
its not a bad idea, do you have a wideband? I boost 22-23 psi while pushing 8.5* of timing at 3500 rpm's with a safe AFR
Old Jan 20, 2006 | 05:40 PM
Ph3n1x's Avatar
Installing Wideband NExt week, just got the EBC installed and did a couple of WOT. I'll just run it safe at 1.55 bar or so.
Old Jan 20, 2006 | 08:19 PM
Jakeg97's Avatar
Easy question:
depends on the year of your evo
Old Jan 21, 2006 | 08:15 AM
Ph3n1x's Avatar
2005
Old Jan 21, 2006 | 08:26 AM
GTKage's Avatar
1.45 bar if u have a 2003-2004 evo and 1.55 if u have a 2005+
Old Jan 21, 2006 | 04:56 PM
blkdinan's Avatar
I would stay at 21-22 until wideband installed. I started to pull timing at 23 and above on my 03 until I added 104 unleaded.
