help with aftermarket intake
Old Jan 20, 2006 | 06:47 PM
mitsitech's Avatar
hey all, im new here...
i run a search on this topic but came up empty, so if it is here i apologize.....
i work at a mitsu dealer and dont have alot of experience with aftermarket evo parts, because the dealer i work for normally stays away from this type of thing. but i like working on this type of thing and am still learning about modding evo's, and i got the dealer ok with this type of thing, but i have to do my own research and learning........anyway, sorry about rambling, here is my question....
i have a 05 evo in the shop that has some mods, i dont know all of them but it has a "weapon R" short runner intake manifold.....when the car came in it had a bad oil leak, which is the oil pump housing, but the car also ran like ****. it wouldnt stay running when cold, and it would idle at 2500 rpm when warm, and idle would go up and down....when i was cleaning off engine to find leak(using brake cleaner) the engine would start racing...ok vacumn leak that i thought was gasket......so i pulled manifold and found a 6 inch split when the edges are welded together. i want to know if anyone has experience with this manifod and if this happened to anyone else....oh im sure the part number on manifold is #1003 or 1103. also the customer told me intake was only on car for about 1 month....1000-1200 miles
i know im a tech making a living, but i like working on modded cars and im trying to help out one of my customers.....
thanks for any input, and anyone in s.w. florida needing a good guy to take your lancer/ evo .....im your man..
Old Jan 20, 2006 | 06:50 PM
jrsimon27's Avatar
put back the stock manifold
Old Jan 20, 2006 | 06:54 PM
mitsitech's Avatar
that was my thought too.....a shost runner sheet metal style intake seems a little unnecessary for street use to me, especially for 800 bucks....but he likes it and i dont think he has stock maniflod.......any ideas?
Old Jan 20, 2006 | 06:56 PM
jrsimon27's Avatar
first of all i think he needs a tune for that manifold so its better for him to get the stock one back or you could repair the damaged manifold.
Old Jan 20, 2006 | 07:02 PM
mitsitech's Avatar
i would repair if i could, but i dont have access to the equiptment to re-weld it....thanks for reply...i appreciate it
Old Jan 21, 2006 | 02:17 PM
mitsitech's Avatar
any more ideas? comments?
also where could i find info on the tuning you where talking about, anyone know of a good place in sw florida, or do you all just send pcm's out for programming? any help would be great
Old Jan 21, 2006 | 03:34 PM
Ultimate CC's Avatar
central florida turbos is located in florida and I know they do evos, I am not sure who else is based out of there, and there is everything from reflashed ecu to standalones available for the evo8
Old Jan 21, 2006 | 04:00 PM
jj_008's Avatar
It sounds like the problem is the crack in the manifold. Either fix the manifold or replace it w/ the stock one. Tuning isn't the problem.
