MBC or WG problem
Old Jan 20, 2006 | 11:08 PM
johnjonfenomeno's Avatar
MBC or WG problem
Guys I have a hallman mbc pulled all the way out to run just wg pressure. It does this fine up to a certain point 5600 rpm then the boost starts going up up and away. What could be the problem. Could my HKS BOV adjustment be causing this problem?
Old Jan 21, 2006 | 12:05 AM
mikiblueeyes's Avatar
bov has nothing to do with boostcreep. make sure mbc is connected the right way, otherwise it'll do that.
Old Jan 21, 2006 | 12:23 AM
the way its set up is... side to wg bottom to turbo
Old Jan 21, 2006 | 10:28 AM
walkedu's Avatar
That setup is correct. Try using a little mobil 1 fully synthetic bearing grease on the ball. Check this thread out.
https://www.evolutionm.net/forums/sh...4&page=1&pp=15
Old Jan 21, 2006 | 10:35 AM
Jakeg97's Avatar
try connecting to bov line
https://www.evolutionm.net/forums/sh...04&postcount=3
Old Jan 21, 2006 | 10:58 AM
dan628's Avatar
I think that using the turbo as a source is the best way to hook up a MBC. I used to have mine T'ed off the BOV and had some issues, like jerky shifts bucking, etc... Now it runs really smooth and I build full boost by like 3000-3500 RPM's
