FQ400 engine oil?
FQ400 engine oil?
I understand all "stock" EVO's are recommend to run on Mobil 10w-30, right? Does this recommendation also count for the FQ400? As most people tend to go a grade higher like 10w-40 (in fact most people even go for 50 and 60 grades) when the power is above standard, so I wondered what the official distributor and their tuners went for...
Originally Posted by gb_junkie
i heard that the fq400 needs some sort of special shell gasoline, is this true?
I think you are still supposed to use Mobile1 10W-30 for warm temps and can use 5W-30 for colder temps. Changing the weight and viscosity of the oil is not recommended as the design of the oil pump and passages haven't been changed from regular EVOs.
Jakeg97
188
Apr 13, 2009 09:57 AM
