same boost leak every 1-2 months
Old Jan 25, 2006 | 08:05 PM
SSKILLA's Avatar
This boost leak keeps coming back up inthe same place every month or so....it occuring at the flange on the intercooler pipe where it meets the cold side of the turbo.......anyone know why this would keep happening?......im guessing its engine movement so i ordered a Motor mount but im not exactly sure this will solve my problem this has been the 7th time i have to get a new gasket and reseal the flange
if anyone can help with some info it would help a ton by the way i have a greddy intercooler kit with the lower piping
Old Jan 25, 2006 | 08:14 PM
WHTEVO's Avatar
Try one of those couplers that have the section in the middle bulging out so it allows for some flex. They are also known as "hump hose". Good luck.
Old Jan 25, 2006 | 08:15 PM
SSKILLA's Avatar
does it sound like a engine movement problem though?
Old Jan 25, 2006 | 08:19 PM
WHTEVO's Avatar
I personally have not had this problem but it is possible. It all depends on how hard the car is driven/shifted which causes the engine movement. I doubt the gasket is failing for no reason other than excessive movement or stress on that particular area. Those couplers are like 20 bucks so it would not hurt to at least try it; it may solve your issue. Good luck.
Old Jan 26, 2006 | 09:31 AM
matt55's Avatar
Yes , engine movement can caused this .
I've got a leak from the same place while just working on the timming belt (which involved me droping the motor about 1" in the front) .
The motor-mount should help alot .
Old Jan 26, 2006 | 02:39 PM
C6C6CH3vo's Avatar
Lots of movement in the area (engine to body difference) also changes of temperature most extreme on plumbing in that area.
Solution: Napa has $4 tee clamps which you can torque 80 in/lbs - about 3 times the clamping force than the stock ones.
You can also order directly from McMaster - Carr. Put these clamps on and the hose will burst before you get a leak on a fitting.
Old Jan 26, 2006 | 02:41 PM
David Buschur's Avatar
Install a front motor mount and you will see the problem fixed and better shifting. We have them instock of course
David Buschur
www.buschurracing.com
Old Jan 26, 2006 | 03:48 PM
SSKILLA's Avatar
will the lower mount alone do the trick?
Old Jan 26, 2006 | 07:06 PM
SSKILLA's Avatar
hey by the way on adjusting a engine damper what makes the motor stiffer making the damper shorter or longer???
Old Jan 27, 2006 | 07:30 AM
Yes, just the front engine mount should take care of the problem.
David Buschur
