needs some clarification
Old Jan 27, 2006 | 07:43 AM
antspeed's Avatar
Im buying an evo and i need some clarification. I have heard the stock ecu is very sensitive to mods in that the adaptation may acutally cause the engine to lose power. In order to keep the factory warranty i just want to do an intake and exhaust. Will i run into any problems?
Old Jan 27, 2006 | 07:49 AM
Compjoc's Avatar
The intake can make u loose power without a tune. You won't get alot out of the exhaust without a tune.
Old Jan 27, 2006 | 07:51 AM
AtO-MiX's Avatar
well your going to need a flash/tune for the intake just do a drop in.The evo takes mods very well, i think ur thinking about the STi.
Old Jan 27, 2006 | 07:52 AM
JTB's Avatar
JTB
Not true. The Evo responds great to mods. Adding an exhaust just adds 15-20 whp.
Getting the ECU reflashed is also quite easy and there are a lot of vendors that can do that for you. You will not need to do an intake as the stock air box is actually very good.
If, however, you are looking at a IX then you will definitely want a reflash as the ECU will compensate for the increased flow of an exhaust and you will not yield much power. That being said a IX with an exhaust and reflash produces some truly amazing results.
Good luck.
BTW -- I went with Vishnu and have been very happy
LRM1981
Apr 13, 2011 08:27 PM
mullen
Aug 6, 2010 08:00 PM
rolly1818
May 8, 2010 03:14 AM
michow87
10
Apr 24, 2008 04:07 PM
dj_subculture
Mar 12, 2007 01:18 PM
