28 psi on stock motor?
Old Feb 2, 2006 | 06:27 AM
Derek888's Avatar
Currently im running 26 psi on alky and 93 octane on stock 2.0 bottom end. I want to turn the boost up to 28 psi when I install the GT35R...you think the stock bottom end can handle it? I have a fully built race head so im not worried about the head only the bottom end. Was wondering how long the engine would last on 28 psi. Maybe I asked this question before but I forgot the answer.. my memory isnt so good
who has run this much boost and for how long?
Old Feb 2, 2006 | 06:48 AM
Rez90's Avatar
as long as the car is tuned properly...it should be fine. I've seen up to 35 pounds on a stock motor and 35r without problems.
Old Feb 2, 2006 | 06:54 AM
Derek888's Avatar
dam.... 35 psi lol
Old Feb 2, 2006 | 06:58 AM
levo2nr's Avatar
yeah sean ivey is running 35 psi ....
that car is freaking fast....
i though i was going to die....LOL
Old Feb 2, 2006 | 09:03 AM
sleet's Avatar
Yep, you'll be fine with 28PSI
Old Feb 2, 2006 | 10:14 AM
IXmr321's Avatar
are you serious i thought 26 was gonna be pushin it on a stock block 35?!?!? holy crap
Old Feb 2, 2006 | 10:17 AM
BJai02's Avatar
Nope, at 26psi, you are only pushing the stock turbo
Old Feb 2, 2006 | 10:23 AM
lbcevo's Avatar
It probably isn't a good idea to go over 28 psi or 400 whp daily without building the shortblock. 35 is a bad idea. Knock at that boost and power is a dangerous thing and you may need a whole new block if a busted rod puts a hole in it. Why not just do it and get the piece of mind? I am.
Old Feb 2, 2006 | 10:25 AM
MikeMAN's Avatar
28psi is insignificant, you should be looking at an end HP goal as the bottom ends limit..
Old Feb 2, 2006 | 10:43 AM
TrinaBabe's Avatar
knock on any motor will kill it... built or not.
35 psi should be ok as long as you have headstuds. I run 28 all day with no ill effects and like others said, people like Sean run over 30.
Old Feb 2, 2006 | 10:45 AM
levo2nr's Avatar
hey Trinababe r u running with alky too at 28 daily?
Old Feb 2, 2006 | 11:10 AM
TrinaBabe's Avatar
If you can run 28psi on pump w/ no alchy you are the man Yes I spray methanol in the car.
Old Feb 2, 2006 | 12:40 PM
silverofs's Avatar
me & one other guy run @ 28 psi & have been the last year he has a 65lb min turbo i have 70+ lb a minute turbo & we both have had no problems..
(he has rod bolts & head studs i just have head studs) just race gas for us though.
i plan on running around 30-32 psi this year though so we will see what happens
Old Feb 2, 2006 | 12:46 PM
EvO6-RS2's Avatar
Derek888
How long you been running 26psi?? Do you have ARP headstuds??
THanks
Old Feb 2, 2006 | 12:48 PM
housedj's Avatar
i run 25 PSI all day long on the '03. i ran it for a couple months at 30PSI but there was no gain in power due to the stock turbo/no cams. the block if i recall is pressure tested to 40PSI on stock internals. you can take it even further if you change pistons & rods...
