High Impedance Injectors
Old Feb 2, 2006 | 07:04 AM
unclecomfort's Avatar
I knew Evo uses low impedance injectors but does anyone know any high impedance injectors that can fit into the evo?
Of course I dont intent to use it on an evo. I need it for other application.
Old Feb 2, 2006 | 07:50 AM
4G63>OOOO's Avatar
The Evo uses low impedance injectors.
High impedance injectors will not work unless you do a complete rewire of the factory harness.
That being said, delphi, RC Engineering and a few other vendors offer all sorts of injectors.
Old Feb 2, 2006 | 07:01 PM
hondafan's Avatar
if evo injectors are the same as DSM injectors, they fit into honda's and thy're high impedance. what i'm trying to say is that honda injectors(high)will fit an evo if evo and dsm injectors are the same. also, most stand alone's allow you to use either type of injector.
Old Feb 3, 2006 | 07:26 AM
Ted B's Avatar
The EVO uses low impedance injectors.
If one uses a standalone, he needs to check if it comes equipped with the proper drivers to run low impedance injectors. If not, the correct driver pack should be purchased ($$). Otherwise, overly large injectors will be needed as a band-aid fix, and I can't think of one good reason why that would be desirable.
2bar_evo
May 29, 2015 10:01 PM
jameswwt
Nov 19, 2014 05:24 AM
kika747
Sep 30, 2014 12:42 AM
JustAfewPosts
May 23, 2013 03:29 PM
