Midrange grunt
Old Feb 4, 2006 | 02:45 PM
Rnm's Avatar
Rnm
Stock 03's aren't that fast to begin with especially compared to 05 Evo's and 06 Evo's. Do a flash and a turboback and that will awake your car, but do check for boost leaks in the first place.
Old Feb 4, 2006 | 02:57 PM
asstard's Avatar
Originally Posted by rartist
I had a brisk sprint on my stock 03 with a dealer window stickered Nissan Altima 3.5. I was just able to keep up with him, gaining slightly; going from midrange on up. My Evo had a tough time doing it. I see 19.5 psi boost QUICKLY tapering to about 16psi in anger. The thing just feels soft.
I have no other Evo's to test this against, should I be looking for a problem? I have been suspicious of a boost leak for a while, and I think I"m going to break down and make a tester and go on a bug hunt. I can hear the turbo whine oner power, and a big whooshing noise. Nothing to test against so I don't know if that's good or bad, I guess it will pay to know. I have been suspicious of the stock BOV under load ever since I was chasing another problem that I fixed.
I'm planing on a reflash this spring that will make things better. I can't help but wonder if something is messed up.
The stock 03 is suppose to boost 19.5 and drop to 16.5. Since you didn't start from 0, but instead started from a roll, I am not surprised that you just barely gained on the Altima.
