View Poll Results: Which selection best describes your situation?
Did Bleed Lifters - NO NOISE
30.43%
Did Bleed Lifters - HAVE NOISE
16
69.57%
Voters: 23. You may not vote on this poll
Aftermarket Cam Noise (tick)
Old Feb 6, 2006 | 01:22 PM
Jeff_Jeske's Avatar
I am about to install cams and cam gears. I am concerned about cam noise even if I properly bleed the lifters properly and hand rotate the crank a few times.
I just want to get an idea of how many people have unwanted noise from cams.
Old Feb 6, 2006 | 01:29 PM
lexat20's Avatar
Ticking is annoying but from what everyone says, it is normal. I had it even b4 the cams its just a little louder now. You'll hear mine at Autobahn...man I can't wait.
Old Feb 6, 2006 | 02:02 PM
matt55's Avatar
I did bleed lifters and no (more) noise (than befor)
Old Feb 6, 2006 | 03:01 PM
CFaber's Avatar
no bleeding here...no ticking whatsoever
installed by evo/dsm mechanic with extensive 4G63 experience
Old Feb 6, 2006 | 03:06 PM
DCSilvrEvo's Avatar
No Bleeding. Ticking happens only when low on oil.
Old Feb 6, 2006 | 03:07 PM
lbcevo's Avatar
I had some ticking for awhile when cold after installing 272s, but now it's gone or not noticeable.
Old Feb 7, 2006 | 09:22 AM
Ludikraut's Avatar
I had some ticking with the stock valvetrain and HKS 272s ... but I do not think the lifters were bled. I performed the "bleeding" procedure (aka lasher adjustment IIRC) and it got a little bit better.
My current setup of HKS 280s and a supertech valvetrain has no ticking.
l8r)
P.S.: you should add more options to your poll (i.e.: didn't bleed lifters options and i don't know option.). Might get more votes....
Old Feb 7, 2006 | 10:35 AM
Jeff_Jeske's Avatar
As for the options.....if they dont know that doesn't help me.
I will be bleeding them so the other choices do not apply. It should be standard proceedure.
I do not want a ticking car.
Old Feb 7, 2006 | 10:58 AM
anjapower's Avatar
bled the lifters...no ticking after cam install.
Old Feb 7, 2006 | 05:33 PM
Takahashi's Avatar
So much work for just cams... Makes me wanna not get them anymore...
Old Feb 7, 2006 | 05:50 PM
Ultimate CC's Avatar
bleed them and still got the noise, used to it now
Old Feb 7, 2006 | 06:00 PM
anjapower's Avatar
you do realize bleeding the lifters is a 5 minute affair right?
Old Feb 7, 2006 | 06:07 PM
dubbleugly01's Avatar
bled lifters, no more noise than before the cam install. Except for maybe 30 seconds while the lifters refilled with oil. I will get some noise on a cold morning, before the engine and oil heat up, but I've got 45K miles on my valvetrain, and I relate it to normal wear and tear, and not the cams.
Old Feb 7, 2006 | 06:10 PM
Takahashi's Avatar
Hahaha. Did not know that...
Old Feb 7, 2006 | 06:19 PM
Jeff_Jeske's Avatar
I dont care about the work.....but the noises....oh now that would **** me off to no end. I would hate to have a $30k car that sounds like its on its last leg.
I wish there was a better way to determine why some have noise and some don't.
